TLR 22T Thread
Old 02-05-2014, 02:02 PM
  #5446
addelrio's Avatar
Originally Posted by 00zx9jjb View Post
Thanks andrewtom, I'm going to order the Mip diff kit tomorrow.
Check fleebay I remenber the diff ring and balls from mip for around $4.
addelrio is offline
Old 02-06-2014, 04:11 PM
  #5447
I got a gear diff for it, there's kind of a bevel on one side of the gear and the screws that hold it together on the other. Does it matter which way it goes in?
00zx9jjb is offline
Old 02-06-2014, 04:14 PM
  #5448
Casper's Avatar
Trader Rating: 34 (100%+)
Nope should not matter which way it goes in.
Casper is offline
Old 02-06-2014, 04:48 PM
  #5449
Thanks Casper, Finally got the truck on the track last nite. Once I knocked the rust off my skills somewhat, I was very impressed with the handling. Only thing that happened was front ball cups. Is it correct to put tlr22 aluminum rear hexes on the front of my 22t to prevent the cups from popping off?
00zx9jjb is offline
Old 02-07-2014, 07:59 AM
  #5450
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yes, that'll solve the issue.
Frank Root is offline
Old 02-07-2014, 09:43 AM
  #5451
Also I know some people are going with captured ends by the wheels. Not sure what is best/cheaper. Just some food for thought
Sodakota is offline
Old 02-07-2014, 11:36 AM
  #5452
Casper's Avatar
This truck has been known to have a small problem with steering links popping off. This is typically solved with alum clamping hexes to reduce front wheel flex but some opt to use a captured ball cup instead.
Casper is offline
Old 02-10-2014, 12:28 AM
  #5453
therainmaker's Avatar
Any ideas on how to remove bumpsteer? Searched the thread and go no results. Tried shims inside and outside and it only made it worse.
therainmaker is offline
Old 02-10-2014, 03:08 AM
  #5454
+1, would like to know too!
Playing with spindle height maybe, but should modify droop also?
kjrell is offline
Old 02-10-2014, 08:08 AM
  #5455
I think I read somewhere that the new 2.0 stearing rack helps. I haven't tried it yet but that might be a good starting point.
Sodakota is offline
Old 02-10-2014, 08:15 AM
  #5456
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
For bump steer, what I found that works for me, I adjust the steering tie-rod to a similar angle as the camber link tie-rod.
Keep in mind that some setups require bump steer in order for them to work properly. It is like making a cake, you forget or change one ingredient and it turns out terrible. So it can be your friend.
Kraig is offline
Old 02-11-2014, 01:20 AM
  #5457
Regarding the aluminum upgrades TLR offers. What is mandatory and what is optional. Only looking for performance enhancing. I did all the available upgrades plus some carbon ones on my 22 SCT. Spent 3 months and went throught two trucks dialing in a setup and it dominates. But I'm fresh to the 22T platform and could use some guidance. My T4.2 is good but I want great. My team manager harasses me constantly about running TLR and I'm looking to prove him wrong.
Old 02-11-2014, 09:23 AM
  #5458
I would also like to know what are the must have hop ups to make these trucks great. I just ordered a 22t before they are all gone.
wrenchinmonkey is offline
Old 02-11-2014, 09:46 AM
  #5459
TLRacing
Frank Root's Avatar
No washers, in or out. You can also try the 22 2.0 rack, which has a 2mm higher ball stud on the inside/rack which helps. And we also have Low Mount Ball Studs which can help: http://www.tlracing.com/Products/Def...odID=TLR234000.
Old 02-11-2014, 12:10 PM
  #5460
Will the low ball studs increase the ball cups popping off? I currently run all lunsford ball studs/ turnbuckles and only have that issue on the steering links. Prob going to captured ends.
