TLR 22T Thread
Old 09-16-2013, 03:27 PM
  #4936
forwardonly's Avatar
Now my buggy has a partner! Just need to get it dirty!
forwardonly is offline
Old 09-17-2013, 05:15 AM
  #4937
Trader Rating: 16 (100%+)
where can I find captured rod ends for this truck? Any specific ones or just any brand will work?
Mullet1 is offline
Old 09-17-2013, 09:22 AM
  #4938
I have seen photos in this thread of guys using the shock ends as captured rod ends.
Banshee8530 is offline
Old 09-17-2013, 09:27 AM
  #4939
Ranger411's Avatar
Trader Rating: 29 (100%+)
I read that TRA3643 Traxxas Camber Link Turnbuckles 49mm are a direct fit. I myself just got a 22T and bought a set. They still aren't to my house but they were worth a shot for 5 bucks.
Ranger411 is offline
Old 09-17-2013, 10:29 AM
  #4940
Trader Rating: 106 (100%+)
Love the paint. nice job!
eddiemoney13 is offline
Old 09-18-2013, 09:42 PM
  #4941
mxracer458's Avatar
Trader Rating: 47 (100%+)
where do you guys like your short battery postion at on indoor med bite clay? on my 22 i have my battery all the way forward, just enough room to have my reciever between the servo and battery tray. just not sure where to start on this truck.
mxracer458 is offline
Old 09-19-2013, 11:54 AM
  #4942
Ranger411's Avatar
So my wing got broken off last night. Is there a direct replacement for it or do you guys just make your own our of scrap. If I do leave it off what will I loose or gain in performance?
Found them, called wings not spoilers for these. Still curious on my other questions.
Old 09-19-2013, 01:06 PM
  #4943
Casper's Avatar
Trader Rating: 34 (100%+)
They do affect performance. You would think not so much but they do help with down force for stock and modfied.
For anyone else looking for them.
http://www.tlracing.com/Products/Def...ProdID=TLR8120
These spares are thicker than the stock ones as well so they last longer.
Casper is offline
Old 09-19-2013, 02:19 PM
  #4944
Stevomatik's Avatar
I usually make mine out of scrap lexan and bend it upward,... they make replacements that you can buy on LApartshouse.com. Instead of screwing them on the upward slant in the rear of the body I usually screw them down on the flat part of the body before the rear upward slant begins, I found them to last longer in this position. The jconcepts finnisher body has this design implemented on their 22t body
Stevomatik is offline
Old 09-20-2013, 06:53 AM
  #4945
I just built my 22t and was wondering about locking the diff, would this be good for racing at all ?
shauny2036 is offline
Old 09-20-2013, 08:23 AM
  #4946
klaymon's Avatar
Trader Rating: 71 (100%+)
No. Your separate thread you asked in has already covered it. Not advisable at all.
klaymon is offline
Old 09-20-2013, 08:32 AM
  #4947
cotto68's Avatar
Do not leave it off, the worst mistake that you can make is assuming that this is just a part added for looks.
Rc cars/trucks are researched and developed much the same as full scale racing and all the parts are there for a reason....especially rear wings .
Leaving your wing off is like running slicks on a clay track.
cotto68 is offline
Old 09-20-2013, 09:34 AM
  #4948
eddomak's Avatar
Default AMain Special
Finally finished mine. First time trying something with a ball diff, so let's see how it goes tomorrow.
Paint job goes with my SCTE (see avatar).
eddomak is offline
Old 09-20-2013, 01:21 PM
  #4949
Casper's Avatar
The diff is not there to be a pain it is there to help the truck turn. If you lock the diff you will get great forward bite but the truck will push off the truck. It will not turn at all.
Casper is offline
Old 09-21-2013, 06:51 AM
  #4950
eddomak's Avatar
Questions?? 22T Wind Down Noise?
Hi,
Just tested the 22T and it all seemed good except after an hour or so there seemed to be a whine/noise when letting off the throttle. Just wondering if this is normal? The motor is a 10.5T sensored brushless motor, and it is my first time running a ball diff arrangement. My SCTE is noisy, but that's just gear meshing.
Anyway, here's a video with the noise when the throttle is released, any suggestions as to whether this is normal or what the problem (more importantly the solution ) might be? Thanks in advance!
+ YouTube Video
eddomak is offline
