TLR 22T Thread
Old 07-25-2013, 07:49 AM
  #4681
By loose stuff, i mean slippery, like dusty or sandy track
The thinner the oil, the freer the diff will be
Thicker oil will give a more locked diff
Freer diff is better for slippery tracks
More locked is better for grippy tracks
Hope it helps
kjrell is offline
Old 07-25-2013, 10:35 AM
  #4682
JBrad's Avatar
Anyone run the aluminum drive shafts? Worth the coin?
JBrad is offline
Old 07-25-2013, 10:39 AM
  #4683
Carranza76's Avatar
They are only good for stock racing. If you use in Mod they will not last.
Carranza76 is offline
Old 07-26-2013, 01:44 AM
  #4684
Stevomatik's Avatar
Yup only for stock... I learned the hard way, one snapped right off because I was running mod... Stupid me
Stevomatik is offline
Old 07-26-2013, 04:13 AM
  #4685
Trader Rating: 17 (100%+)
So 13.5 and 17.5 Stock. Has anyone noticed a big difference? I'm thinkkng of picking them up as well.
RodimusPrime49 is offline
Old 07-26-2013, 06:36 AM
  #4686
Thank you for explanation and for the links
roman76 is offline
Old 07-26-2013, 07:53 AM
  #4687
Carranza76's Avatar
Welcome, I read those links for a few months when I got started in this hobby and they help a lot but do not be afraid to ask questions cause it will save you money in the long run.
I have not run them personally but I hear good things about them. I would stay away from super stock 13.5 with them and use them for 17.5 only but maybe Casper or Frank would be able to give a better opinion.
Old 07-26-2013, 08:00 AM
  #4688
Casper's Avatar
Trader Rating: 34 (100%+)
I would not say a BIG difference but every little bit helps. 17.5 they should last a long time. In a truck 13.5 will be pushing it. They will work but I would not expect them to last a life time.
Casper is offline
Old 07-26-2013, 12:22 PM
  #4689
Suspended
Trader Rating: 89 (100%+)
I hate to ask this: But.... I just bought a 22T and was curious what kind of info. I should be aware of. There are soooo many pages in this tread I'm hoping someone familiar w/the thread and/or truck would be able to give out some pointers. This is what I got:
TLR Aluminum Servo Mounts TLR1550 ($35)
Diggity Designs Carbon Battery Brace ($35)
TLR Aluminum Shock "Bleeder: Caps TLR5065 ($35)
TLR Aluminum Rear Camber Block TLR2060 ($30)
TLR Aluminum 30* Front Pivot TLR1105 ($25)
TLR Aluminum Front Camber Block TLR2059 ($25)
TLR Aluminum Rear Std width Hexes TLR2938 ($25)
TLR Aluminum 4* LRC rear pivot block TLR2986 ($15)
TLR Aluminum Servo horn 25t installed TLR1557 ($10)
TLR Threaded Titanium Threaded Rear outer Hinge Pins TLR2056 ($10)
TLR Threaded Titanium Threaded Front King Pins TLR1043 ($10)
Losi Aluminum front hexes (Ten-SCTE, $8)
Traxxas captured steering links ($8)
BRAND New Team Chris ceramic diff balls installed ($25)
BRAND new Diff rings installed ($4)
BRAND new MIP hardened thrust washers installed ($8)
BRAND new Team Chris ceramic thrust balls installed ($12)
The transmission has been raised 1mm with the lexan pieces
Sarinexia is offline
Old 07-26-2013, 12:51 PM
  #4690
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Talking Congradulations
Nice going your going to Love this Truck. Look's like you have it all covered. I would go to Caspers Page and Install his setup: http://www.casper-rc.com/
Click on Information page > then Setups
Go to your Local track and see what tire combo the top guys run. Then see what Motor is run the most so you get to race a lot.
Mitten makes some cool side guards: http://www.rctech.net/forum/r-c-item...ard-ext-4.html
mbtoolmaker35 makes the alu steering slider: http://www.rctech.net/forum/members/...35-144019.html
I also have some sliders of His , Brass and Alu. PM him or Myself I will help you all you like.
XXXDad is offline
Old 07-26-2013, 12:53 PM
  #4691
Casper's Avatar
Not sure the 4 deg rear toe block was needed but if you are on real low traction might not be a bad idea.
TLR released 22T specific front hexes. If you use the SCTE ones you want to put about .5m between the drive pin and the bearing to space the SCTE hexes out a touch.
I would also recommned the TLR334000 orings for the shocks.
http://losiracing.blogspot.com/2012/...p-o-rings.html
Casper is offline
Old 07-28-2013, 08:53 PM
  #4692
does anyone know what set up Dakota ran at the shoot out?
blingy is offline
Old 07-29-2013, 10:33 AM
  #4693
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I am working on getting that from him, and we'll get it posted on TLRacing.com.
Frank Root is offline
Old 07-30-2013, 12:57 PM
  #4694
Stanfsu's Avatar
Trader Rating: 294 (100%+)
I just picked up this kit to run in a small in-door off-road dirt tract. What spares should I keep in the toolbox?
Stanfsu is offline
Old 07-30-2013, 01:44 PM
  #4695
XXXDad's Avatar
Thumbs up The captiv steering turnbuckles.
It does not need much other than regular brakeabls, like arms. Use CaspersSetup works great. Insall his Captve Thrust bearing in the Dif.
What kind of dirt?
XXXDad is offline
