TLR 22T Thread
Old 05-28-2013, 08:45 PM
  #4531
AndrewTom's Avatar
Originally Posted by L.DENG View Post
Hello, guys.
has anyone measure the 22sct front and rear shock length from eye to eye? or some one could please have a measure?
cheers!
i don't know how much Exactly, but I think the 22sct shocks are around 2-3mm shorter then the 22t's shocks.
I can check tonite fore you.
AndrewTom is offline
Old 05-28-2013, 09:06 PM
  #4532
Thank you very much, AndrewTom, if u can please measure the exactly shock lengh for these two truck. Or maybe point out which page in this thread has the imformation I need. Cheers!
L.DENG is offline
Old 05-28-2013, 09:08 PM
  #4533
Casper's Avatar
Trader Rating: 34 (100%+)
Bodies are for sure shorter as they marked them SCT.
Casper is offline
Old 05-28-2013, 11:17 PM
  #4534
AndrewTom's Avatar
okay, this is what i've come up with. (all are approximate)
22T front: 88mm (i think i have 2mm limiters though, so 90 can't remember exactly)
Rear: 105mm (0 limiters)
22SCT front: 85mm (0 limiters and rod end unscrewed one full turn)
Rear: 102mm (0mm limiters.)
all are approximate, i just took my calibers to both my cars. i did the best i could, hope this helps.
what are you building?
Old 05-29-2013, 05:51 AM
  #4535
Thumbs up
Thank u very much, AndrewTom. That is very helpful!
I still racing with the Hongnor NEXX10SC, wanna try the losi bladder shock and make difference on it. Gut too much parts for spare.
Hope losi guys don't mind I asked question here~
Cheers!
L.DENG is offline
Old 05-31-2013, 12:41 AM
  #4536
Trader Rating: 37 (100%+)
Okay guys... Here is my first hack at the dropdown setup sheet. LMK what would help to improve it. I'm happy to listen to any suggestions.
https://dl.dropboxusercontent.com/u/...etup_Sheet.pdf
ufoDziner is offline
Old 05-31-2013, 08:09 AM
  #4537
Carranza76's Avatar
https://www.dropbox.com/s/p3pb58tp0e...etup_Sheet.pdf
Thats pretty Sweet
Carranza76 is offline
Old 05-31-2013, 11:30 AM
  #4538
HollywoodRC's Avatar
Default Drop Down Set Up Sheet
Originally Posted by Carranza76 View Post
Thats pretty Sweet
Plus 1. I like it. Now I need one for my Tekno eb48!
HollywoodRC is offline
Old 05-31-2013, 05:46 PM
  #4539
Trader Rating: 25 (100%+)
Thumbs up
Parts for sale: http://www.rctech.net/forum/r-c-item...svr-parts.html
IVAN RM is offline
Old 05-31-2013, 07:20 PM
  #4540
AndrewTom's Avatar
Originally Posted by IVAN RM View Post
wrong thread
Old 06-01-2013, 01:24 AM
  #4541
KalEl63's Avatar
Just wondering what I may be able to do to the T to get more steering out of it especially exit steering under power it just understeers.
I run on a hard packed track which can come up dusty at times but overall medium grip
I was thinking of shortening the front camber links or looking at the shimming of them
I am running Casperís set up.
Any ideas/help would be appreciated.
KalEl63 is offline
Old 06-01-2013, 03:10 AM
  #4542
stinky cheese's Avatar
Trader Rating: 21 (100%+)
I am running Casper’s set up.
Some things you can try for more on power steering
Move rear hubs backwards.
Move lipo battery forward.
Harder rear spring.
Some lead weights up the front.
stinky cheese is offline
Old 06-01-2013, 07:24 AM
  #4543
AndrewTom's Avatar
Harder rear spring.
all if this and you could also try less castor
what are you running for kick angle? 30? 25?.
Old 06-01-2013, 07:40 AM
  #4544
KalEl63's Avatar
Running 30 kick and 0 caster.
I have tried the hubs all the way back and didn't like the way it handled
Not to say I wont give it a try again
Battery is all the way forward
Just trying to think of other things I can tell you as I appreciate the help
KalEl63 is offline
Old 06-01-2013, 08:30 AM
  #4545
Modified51's Avatar
Hey guys. I was wondering if there is a way to get more steering out of the truck as the track I run has alot of hairpins that i have to slide the truck to turn it. I was told by someone that for the the steering link on the wheel side he had drilled holes in front and slightly to the side of the stock ones to help that. What are your thoughts?
Modified51 is offline
