TLR 22T Thread
Old 05-16-2013, 07:00 AM
  #4486
carbons2k's Avatar
Trader Rating: 21 (92%+)
Originally Posted by XXXDad View Post
I use caspers steup.. works great.
I can never use a Suburb in the REAR! It never worked for me... it's just my experience.
What works for me is TIRES.... go with a Super Soft Holeshot or DD. use the Suburbs in the front. Maybe even try a harder compound front tire.
I cant use a holeshot or double D. My track is indoor and its all clay. The actual tire of choice is a slick but they seem to not work so well on my 22T. The suburbes feel good everywhere else on the track except for coming out of the turn, Im not really looking for a tire change, but mainly a setup change and Im not sure how to get some better traction coming outta the turns.
carbons2k is offline
Old 05-16-2013, 07:17 AM
  #4487
dvsstrike's Avatar
Originally Posted by carbons2k View Post
Can anyone help me try to get some more forward bite out of my truck? The car is a little squirlly in the back when im coming out of a turn, especially the turn before the straight. I have 27.5 oil all around, stock springs, 3degree pivot block in the rear, 2.5mm anti-squat and im using worn in M4 suburbs. would going to 3.5 degree pivot block help out at all? Thanks!
have you raised the tranny yet? also avid slipper helps
dvsstrike is offline
Old 05-16-2013, 07:47 AM
  #4488
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs down Dont listen then
Those tires suck in the rear... don't listen then.. use casper set up.. and be done with it! Holeshots work great everywhere ! don't be hard headed....
XXXDad is offline
Old 05-16-2013, 07:50 AM
  #4489
Casper's Avatar
Trader Rating: 34 (100%+)
What is the rest of your setup? Shock locations, springs, camber link positions with ball stud washers.
If everyone else is on slicks I don't think M4 would be the ticket for rubber. Tires are very important for any good setup. And yes 3.3 deg of rear toe in might help but may not be the right answer as well. Too much toe can lock in a car mid corner and make it push.
Like dvsstrike had mentioned have you raised he tranny yet? This helps with on power stability.
Casper is offline
Old 05-16-2013, 08:17 AM
  #4490
carbons2k's Avatar
Haven't raised the tranny yet. How much is the raise... 1mm? As for hole shots, I can't see how they would work on my track. My track is kept very wet with little to no dust cover.
Casper - can I send me your set up sheet?
I'm using this setup but with a 10.5
http://www.petitrc.com/setup/losi/se...2012032325.pdf
Old 05-16-2013, 09:00 AM
  #4491
Casper's Avatar
All my setups can be found at www.casper-rc.com Details on raised tranny are linked on the setup sheet, and you can use AE big bore pistons for the 2 hole pistons if you don't want to make your own.
I am quite suprised to see how light of oil Michael is using on that setup. Front and rear pink springs is quite odd as well.
Sounds like slicks or maybe a small pin tire like a Panther switch 2.0, JC wishbone, PL Ion or scrub may be better for you. If the track is wet clay look at the clay compounds (panther clay, JC Gold, Pro-line MC). Also panther makes a slick ST tire. You will still want to hit it with a dremel sanding drum to rough up the surface a little but much easier then grinding down something with pins already.
Casper is offline
Old 05-16-2013, 11:38 AM
  #4492
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www.rctech.net/forum/r-c-item...-22t-sale.html
My trucks up for sale.
aloksatoor is offline
Old 05-17-2013, 05:32 AM
  #4493
KalEl63's Avatar
While on Tyres for the T what do people find works best on most tracks on the front?
KalEl63 is offline
Old 05-17-2013, 09:57 AM
  #4494
Casper's Avatar
That is too general a question. Indoor clay will typically require a different tire then outdoor dirt. The moisture content of the dirt/clay and the amount of loose stuff as well has how hard the base is will all effect tire selection so to ask what front tire works best on most tracks, does not have a good answer.
Casper is offline
Old 05-17-2013, 01:26 PM
  #4495
Trader Rating: 15 (100%+)
+1 To what Casper said - but have you been to your track yet and checked out what the fast guys are using - go with that! If you simply want something to put on your T to get it going, get a set of ribs, or for bashing, road(hogs) tires.
HeavyD99 is offline
Old 05-17-2013, 06:09 PM
  #4496
The Juice's Avatar
Trader Rating: 25 (100%+)
What is the best approach for softening the front end? What should I change first or together....Springs, oil, or pistons?
The Juice is offline
Old 05-18-2013, 12:16 PM
  #4497
AndrewTom's Avatar
what do you need out of the front end? green is a good spring for this truck in my experience. try 2 hole pistons, I have 2 x1.6mm front and rear with 25wt associated oil in the rear and 30 in the front. works really well!
AndrewTom is offline
Old 05-19-2013, 03:26 PM
  #4498
Casper's Avatar
Yeah do you need less damping, Less pack or just less support?
Casper is offline
Old 05-19-2013, 07:54 PM
  #4499
The Juice's Avatar
I'm getting no weight transfer on breaking and landing on the front is stiff causing the back to kind of slam down. Have 56 piston, orange spring, and 27.5 weight oil.
Old 05-19-2013, 10:50 PM
  #4500
Casper's Avatar
For most setups I see on this truck you are kind of soft already. Most are on green or blue front springs.
What is the rear end?
Casper is offline
