TLR 22T Thread
Old 04-20-2013, 07:47 AM
  #4441
LtngMcQn's Avatar
LtngMcQn is offline
Old 04-21-2013, 11:08 PM
  #4442
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Exclamation Good Times
XXXDad is offline
Old 04-22-2013, 08:36 AM
  #4443
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by cripplethreat View Post
I'm going to be trying my hand at Racing this summer, I am looking into getting a 22T or the 22. I am having a hard time deciding if I should buy the RTR or the Kit. I've never raced or anything of the sort so I plan on running the Novice class and the stock class. I've also never built anything. I just have mini's and Micros.
Take a look at this thread!
http://www.rctech.net/forum/electric...de-thread.html
Lots of good information!
thecman26 is offline
Old 04-22-2013, 07:32 PM
  #4444
XXXDad's Avatar
Arrow Mitten Mud Guards/ Side Pods
Get them from> http://www.rctech.net/forum/r-c-item...ard-ext-4.html
XXXDad is offline
Old 04-22-2013, 07:41 PM
  #4445
XXXDad's Avatar
Thumbs up Also added some .75 Rear Hex
XXXDad is offline
Old 04-23-2013, 07:03 AM
  #4446
Trader Rating: 25 (100%+)
Looks Good. The Carbon Fiber Looks Sick!
Mitten is offline
Old 04-23-2013, 03:28 PM
  #4447
austinspeer810's Avatar
Default Wheel Adjustments
I have been trying to get my wheels back to how they were when I first got the truck. I upgraded to the titanium turnbuckles so I had to put ALL new ball cups onto the titanium turnbuckles. Pain in the butt...yes it was. The rear wheels look the worse. I have tried to adjust them as much as I can but cannot get them right. The front ones are alright but I would like to get them as straight as I can but if they have a little toe in I am fine with that. What turnbuckles do I adjust for the front to look normal and how do I make the rear wheels look normal as well? Thanks...
austinspeer810 is offline
Old 04-23-2013, 03:34 PM
  #4448
Casper's Avatar
Trader Rating: 34 (100%+)
You need to adjust the upper links in the front. There should be plenty of thread to get them adjusted right. Are these links for the 22T?
I can't tell you which way to turn them as I don't know you you pu them on but this is pretty easy to adjust with a turnbuckle tool.
http://www.tlracing.com/Products/Def...rodID=TLR99102
It also helps if you use some type of grease on the threads when you assembly them so they turn easier for adjusting. Just about any grease will work. Black grease, green grease, some use wax or chapstick. All get the job done and make adjusting much easier.
Here is a little video on adjusting camber and ride height.
http://www.youtube.com/watch?v=OqtjxvBHGGk
Casper is offline
  #4449
Personally, get the kit!!! Trust me!!! I bought the RTR because I didn't feel like building it. Just pure laziness. Yes the RTR is cheaper in the beginning, but I have already had to spend 60 dollars on a new servo because I stripped the stock servo gears. I am already looking at buying a new esc which will cost me 150 dollars or more. New motor over the summer which will cost me about 100 dollars or more. Had to buy new tires which cost me about 80 dollars because I purchased them unmounted. I will have spend about 310 dollars not including the tires. Don't forget a new radio but you can find the under 50 dollars on ebay including the receiver and yes I am talking about one with 2.4ghz technology. So in my opinion, buy a kit and build it yourself so you can learn about the truck and how parts go together and as well as making it to fit YOUR racing style and not the general public. One thing I learned in my years is that everyone has a slightly different setup and style of driving and you should make yours to fit your driving preference. Hope this helps
Old 04-23-2013, 04:06 PM
  #4450
So not the ones that connect to the servo for the steering? What about the ones in the back of the truck?
Old 04-23-2013, 04:13 PM
  #4451
Casper's Avatar
They all adjust the same. The steering links you HAVE to make sure they are the SAME LENGTH. Adjust them equally. The camber links you can just adjust to get the camber right and they should be the same length when you are done but the steering links you want to make sure they start the same length and adjust equally so you get the same steering left and right.
Casper is offline
Old 04-23-2013, 04:28 PM
  #4452
Thank you very much!!! I will get to that right now. Another problem I am having is the rear wheels. The motor is powering the wheels but only one. The other is just spinning but not like the other one. The video is below:
http://www.youtube.com/watch?v=YI4wj2kwtgI
Old 04-23-2013, 04:32 PM
  #4453
Casper's Avatar
Pull the tires off. Make sure the pin holding the hex is still there and not broken. Then check both CV joints and make sure the pins all all the way in and not hitting the hubs. Could be the diff as well.
Casper is offline
Old 04-23-2013, 04:37 PM
  #4454
How much is a diff?
Old 04-23-2013, 04:40 PM
  #4455
Casper's Avatar
How much is a diff?
Depends on what is broken and if you want to go with a gear diff or a ball diff.
http://www.losi.com/Search/Default.a...archTerm=22rtr diff
http://www.tlracing.com/Search/Defau...chTerm=22+diff
Casper is offline
