TLR 22T Thread
#4336
22T front body mounts ; keep breaking them
Anyone have a alternative or know how i can get a small quantity of the front body mounts without buying the shock tower kit (@ $9 a pop) as the front mounts keep splitting on me. Pretty much only when no driving at the indoor track, but outdoor/bash track site and on the street. Looks like the Jconcepts Finisher body addresses this as the lexan comes up above the posts; could be a solution.
Thanks.
Thanks.
#4337
Suspended
- but 72/32 is more suitable in the 17.5 buggy, in the 22T you're WAY overgeared.
#4338
same issue here
Thanks.
Thanks.
#4339
Casper or Frank
Im running the Ryan Dunsford set up minus one spacer on front camber link ballstud on a 55x90 indoor high bite track. Blue barcodes in front green in rear. It doesnt seem like the truck has alot of corner speed. Im having to come to almost a stop to get the truck to rotate. Any sugestions? Thanks.
#4340
TLRacing
#4341
#4342
I will try both. Thanks!
#4344
Thanks.
Thanks.
Or maybe TLR can drop 4 body mounts in with the tower.
#4345
Suspended
#4347
I ran my first race on my 22t last sunday. I ran it kit set up, and the front end feels a little twitchy, is there anything I can do that will make it less so?
I ran my 22sct as well, and it has the kit 4mm trail, and I love how it feels comparison wise. i now that apples to oranges in classes, but
#4348
Suspended
You're right, apples to oranges (drastically shorter wheelbase).
I'm not sure why they haven't ordered steering blocks with increased trail either.
#4349
You could also try changing the front shock oil from 27.5 to 30. This should deaden the response of the front.
Everything is a tradeoff so you might not like what else changes, but you'll only know if you try.
#4350
Try changing the rear pink springs to yellows. Softer rear springs won't transfer the weight to the front of the truck as hard.
would changing castor help as well? I have kit 3* on the truck, but I have 0*, 5* and 10* castor block sets handy.
I also have the buggy pivot (25* kick) set too.
