TLR 22T Thread
Old 02-25-2013, 06:41 PM
  #4321
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Cool yes true
Originally Posted by ChrisWolfson View Post
You might get the shocks to work.
But the 22 shocks will cost you more than the car is worth....
XXXDad is offline
Old 02-25-2013, 09:50 PM
  #4322
Originally Posted by HeavyD99 View Post
Hey Casper - is there any reason why TLR says those bleeder cap o-rings are only meant to be used with the aluminum bleeder caps, and not the RTR plastic bleeder caps? I'm about to CA the RTR o-rings into the RTR caps and would like to get this right the first time
The plastic shock caps dont have the same chamfered edge on teh inside that the aluminum caps do and thus the plastic cap wont seal properly with that external o-ring like the aluminum caps will.
hacker07 is offline
Old 02-26-2013, 09:55 PM
  #4323
AndrewTom's Avatar
Originally Posted by sheldbop View Post
What parts are interchangeable from the xxx-t cr to the 22t? dont have to be super specific, just want to know if anything can be swapped over to upgrade a cr to more currents specs.
very, very, very, very, very little.
slipper pads, plates, and spur gears.
everything is different, everything
it is easier to say whats the same, ^ that handful of items i mentioned in this post.
AndrewTom is offline
Old 02-26-2013, 10:17 PM
  #4324
Ant73's Avatar
Hey guys,
We run 10.5 blinky truck in Oz and I have been using the buggy 76t spur as I get to a nice FDR. I notice most of you guys run the box spur. Why? Would I be sacrificing anything doing this? Buggering up rear traction? Motor too close to the tranny? Anything? Please let me know your thoughts.
Anthony
Ant73 is offline
Old 02-27-2013, 08:07 AM
  #4325
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Ant73 View Post
Hey guys,
Anthony
I would aim to have the motor as close to the tranny as you can get it with the motor you are running. I run a 6.5T, so 16/86 is pretty much as close as you can get.
Frank Root is offline
Old 02-27-2013, 08:19 AM
  #4326
Roger H's Avatar
Trader Rating: 19 (100%+)
Frank- im sure this has been asked, i am running a tekin speedo, no boost, with a 7.5. Stock spur and have been going up in pinion becuase it comes off cold. Im up to a 25... are you guys running boost or timing or just perfer the lower gear?
Roger H is offline
Old 02-27-2013, 09:32 AM
  #4327
Casper's Avatar
Trader Rating: 34 (100%+)
I am at 18/84 with my 7.5 Tekin Gen 2 in my 22T. How cold is it where you are racing?
How is the power? What is the Endbell timing set at?
Casper is offline
Old 02-27-2013, 09:40 AM
  #4328
Roger H's Avatar
Roughly 60 degrees. Indoor track, its tighter track. 20 degrees of endbell timing. Power feels perfect, nice and smooth all the way through. Temp on motor is around 100-115.
Also my 22 has a 13.5 with the endbell timing around 30 i run a 33 pinion and it comes off at less than 100.
Could this just be driving style?
Roger H is offline
Old 02-27-2013, 11:22 AM
  #4329
Casper's Avatar
May be. If you like the power and motor is running cool I would not worry about it. Sounds like it is working for you!
Casper is offline
Old 02-27-2013, 04:10 PM
  #4330
Ant73's Avatar
So you wouldn't be averse to using a 70t spur with a 10.5 motor on the truck? Any suggestions on pinion? I was thinking 20 or 21 with an FDR of 8.5 and 8.1 respectively. It's a Thunder Power 10.5 and I usually turn the timing up to 20%. At the moment I run 76/22.
Ant73 is offline
Old 02-28-2013, 08:06 AM
  #4331
TLRacing
Frank Root's Avatar
I don't think it matters if you run a 70T, as long as the pinion/spur ratio is correct for the motor. With that said, I've never run a 10.5T, so I am really not sure what to recommend for gearing, sorry.
Casper might be able to help, he has run a 10.5T quite a bit in his vehicles.
Old 02-28-2013, 09:11 AM
  #4332
rcguy76559's Avatar
Trader Rating: 22 (100%+)
I ran a fully boosted 10.5 with stock spur and 22 pinion. on fairly large track.
rcguy76559 is offline
Old 03-02-2013, 06:11 PM
  #4333
carbons2k's Avatar
Trader Rating: 21 (92%+)
Does anyone know proper gearing fro 17.5 motors? Does this truck gear simiar to a buggy? Ive got a 72/32 and the motor came off at 150ish after 5 mins. My RB6 buggy is geared at 70/31 and doesnt get nearly as hot
carbons2k is offline
Old 03-02-2013, 07:16 PM
  #4334
Just picked up a 22 with lots of goodies. Aluminum slider, +76 hex, rear camber block, rear hubs, 5' caster, lots of extra wheels/ tires and a shorty lipo. Kinda feel like I won the lottery cause I basically got a free car. So now that I got all these extra bits my question is do I take the aluminum bits and put them on my current rig as optional parts or build/ keep it as is to compare to my setup as is? What do you all think?
Oh as a side note I am running only kit parts on my current set up.
Sodakota is offline
Old 03-02-2013, 07:21 PM
  #4335
Disregard the previous post was ment to be in the 22 not 22t thread. I'm just a rookie tech after all
Sodakota is offline
