TLR 22T Thread
#3901
I keep having a problem with the rear washing out. On the clay track it seems to wash out on the turned off throttle.
#3902
What is you ride height(mine was like 24mm at first way to low) raised it to 30/29 much better
shock oils as well( I started with 32.5/30) way to stiff lots of steering zero traction..Dropped to 27.5/25 again much better
I also raised the transmission and added 7g of weight over the transmission.
Also what camber link position are you running? I am running the 1-D block to help the truck keep steering while feeling really planted.
I did try taking the weight off recently and running a shorty car was better but I lost to much traction def gonna put the weight back on there.
#3903
As for ride height I just make sure the arms are level.
I am also using 1D on camber and outer hole on the a arm with the 3rd hole from outside on the shocks. 27.5 in rear shocks with yellow losi springs. I'm thinking of going 20 or 22.5 in rear. I have plenty of steering but thus washing out is becoming a problem.
Yesterday was the first time I ran it since I built it and so far I like the way it drives except for the rear end
#3905
I'm using the gear diff with 5k. Going to drop it to 2k and hope that tones it down.
#3906
Maybe try different front tires. I'm running pink tapers on the front and suburbs on the rear. When the track is damp and the tires are clean the truck is great. When the tires start to collect some clay they have too much grip and cause the rear to whip around. I think sometimes you can have to much traction up front.
#3907
R/C Tech Elite Member
#3908
I'm wondering if these will fit front and rear on the tlr22t? My daughter wants to run these for her bashing sessions she says lol! Thank guys for your time. I see these have the 12mm hex just like the 22t and the offset appears that it should fit no problem. I would also like to know if these will fit on the tlr22sct as well?
1. http://prolineracing.com/wheels/desp...-black-wheels/
2. http://prolineracing.com/tires/badla...-black-wheels/
#3911
#3912
#3914
I understand the on power issue but im having a problem washing out off power during turns. Im thinking thinner fluid in the rear shocks and diff might work till i get the ball diff in.
#3915
Allen
