TLR 22T Thread
#3842
diffs are super goood. i will have to check and see if the tranny is raised up and double check it out.
#3843
Hope that helps!
I did this and myu truck was locked down!
You have to check this frequently too!
If it starts to drive squirley it is more than likely the diff!
#3844
Bump Steer? I've been seeing this in the setup sheets for the 22T. Where is this adjusted? What's a good starting point? What does it do?
Thanks in advance.
Allen
Thanks in advance.
Allen
#3845
This is most common changed by raising or lowering the ball stud on the spindle. Bump steering is an effect where the toe of the car changes with the compression of the suspension. If you look at the tires top down and compress the suspension you will most likely see the toe change a little in the front tires and this is called bump steer.
#3846
Allen
#3847
How can we go about to get some bump in.....I've got bump out on both of my 22t's
#3848
Any chance of getting 75mm 4mm turnbuckles to use on the 22T. I'd like to use all the same size and ball cups as the 22SCT.
#3850
Anyone done a review or have opinion of the Bulldog body for the 22T?
Thanks in advance.
Allen
Thanks in advance.
Allen
#3855
Ran both of my 22T's this weekend, they were really good considering the track was bone dry! There wasn't a tire in my massive box that would have fixed my loose condition but they both handled great considering the conditions! When theres traction though these guys are LIGHTS OUT!
