TLR 22T Thread
Old 08-18-2011, 01:43 AM
  #361
Originally Posted by Poptartninja View Post
If you order from horizon, They show an eta of 10/10.
Awesome, the UK should have them in September then, thats next month!
(The 22 arrived in the UK before the states!)
J A M I N is offline
Old 08-18-2011, 07:38 AM
  #362
carcrazy699's Avatar
Trader Rating: 49 (100%+)
Hey Hey don't rub it in!
carcrazy699 is offline
Old 08-18-2011, 08:47 AM
  #363
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
If you look carefully at the layout at the rear, the shocks sit at the back of the wishbones in mid motor config, rather than at the front in rear motor config.
This means that the 'turrets' that enclose the shocks need to be moved further back on the body to accomodate this. Its why there is 2 shells in the kit. Although no pictures have appeared as yet....
OK that makes sence
thecman26 is offline
Old 08-18-2011, 09:02 AM
  #364
RcRacerBeast's Avatar
Trader Rating: 28 (100%+)
Originally Posted by TreadRCracing View Post
I have to admit that losi did a good job at including 2 bodies. Now unlike the 22, if somebody wants to switch from rear to mid or mid to rear they will already have the body.
Great job losi/tlr
I dont think TLR is going to give 2 bodies. It just be like the 22 you can cut rhe body to fit either rear or mid.
RcRacerBeast is offline
Old 08-18-2011, 09:08 AM
  #365
The guy from my LHS also said that the TLR22T will come with 2 body's and 2 sets of wheels in the kit. That would be great and i would even conider it to order one
addicted2blue is offline
Old 08-18-2011, 09:38 AM
  #366
thecman26's Avatar
+1 here too! Too bad its not going to be available till late october!
Old 08-18-2011, 09:46 AM
  #367
UK.hardcore's Avatar
Being that both shells are found in the spare parts list, not the option list for the mid motor shell i'd say they are both included.
UK.hardcore is offline
Old 08-18-2011, 09:48 AM
  #368
Amain says in the description that it comes with 2 bodies
http://www.amainhobbies.com/product_...cing-Truck-Kit
Old 08-18-2011, 11:27 AM
  #369
jk racing's Avatar
Trader Rating: 20 (100%+)
TLR reps have confirmed, 2 bodies and 2 sets of wheels, no tires.
jk racing is offline
Old 08-18-2011, 11:30 AM
  #370
Features:
Includes both a rear and mid-motor completion option in the same kit
2.5mm hard anodized aircraft aluminum chassis
All-metric hardware so only one set of tools is required
2.2” truck wheels included (No tires included)
Front and rear wheels are the same via 12 mm hex
2 ROAR-legal bodies (Mid and Rear Configuration) included
Adjustable caster via the spindle carrier. 3° included with option (0, 5 and 10°)
12mm Big Bore Aluminum Shock with Bladder Compensator
Gull Wing Suspension Arm Design (Front)
Replaceable Bolt-On front and rear Camber Blocks
3.5mm Heavy-Duty Turnbuckles
Innovative Steering Rack Design
Long-Life Titanium Nitride Hinge Pins
Vertical Mounted Ball Studs
Optimized Battery Tray for multiple Battery configurations
Dual Disk Slipper Clutch with 82 tooth spur gear
Poptartninja is offline
Old 08-18-2011, 12:03 PM
  #371
Wes Lawrence's Avatar
Very cool!
Wes Lawrence is offline
Old 08-18-2011, 04:22 PM
  #372
Wow then TLR is being really kind.
Old 08-18-2011, 05:33 PM
  #373
While I agree with this 85%, the other 15% of me looks at the $299 price tag and thinks the kindness is covered. However I am a loyalist and TLR will get my dollars
dillydalley is offline
Old 08-18-2011, 05:37 PM
  #374
Trader Rating: 52 (100%+)
They are not being kind. They give you the option to run rear or mid within the same kit and the parts come with to run either. You couldn't do that unless they gave you a differant body for mid motor since the shocks are moved the humps in the body also have to be moved. The rear motor body just wont work on the truck in mid motor.........
tonyd is offline
  #375
thecman26's Avatar
+1, but its only $20 more than an RT5 and with the RT5 you get one body and one set of wheels (no tires)... So its pretty even...
