TLR 22T Thread
#3646
Metric drill bits can be ordered through McMaster Carr.
I got 1.5, 1.6, 1.7, 1.8 and it was $9 I think.
http://www.mcmaster.com/#metric-jobb...l-bits/=iosy3w
Get a pin vise and you are good to go. I like Losi std CA and some kicker for glueing holes. Thin goes through the holes too easy IMO.
#3647
Did you notice any difference in the acceleration of your 22T between the 5K and 10K diff oil?
Allen
#3648
Is it any advantage to have the 22T start out at a higher minimum throttle setting? The 'top end' will still be the same no matter what the throttle minimum setting is, correct?
Allen
#3649
Umm. Thanks, but that doesn't really tell any advantage of having a higher number for its minimum throttle setting; just that a lower setting will benefit rock crawlers since they will be able to go a a slower pace.
Allen
Allen
Top end will be the same regardless .
#3650
Hello everyone, I'm getting ready to sit down and order my 22T. I talked to some of the Losi guys at the track today and asked what should I replace while I'm doing the initial build. The general thought was to replace king pins and put the aluminum steering rack on it. Is there anything else I should order with the kit ? Thanks for your help.
#3651
Hello everyone, I'm getting to sit down and order my 22T. I talked to some of the Losi guys at the track today and asked what should I replace while I'm doing the initial build. The general thought was to replace king pins and put the aluminum steering rack on it. Is there any thing else I should order with the kit ? Thanks for your help.
I would definately order the rtr shock caps if you plan on running emulsion style, which is much better than the bladders. I would also order the cool Al servo horns, they look great and you don't have to worry about stripping plastic.
#3652
For those of you who are new to the truck and may have missed this. I haven't posted about them in a while but I will make them as long as people want them.
http://www.rctech.net/forum/r-c-item...guard-ext.html
#3654
Thanks for the reply. I know this is the 22T forum but wanted to post that I tried two hole pistons today on my mid motor car. Went with 1.55mm holes and 27.5 oil front and rear. Left everything else the same and my car was quick. Went 0.2 second faster on my fast lap and the car could be driven harder. I like it and will test more with 1.6 or 1.7mm pistons
#3659
Just a heads up folks, I installed the 22 SCT aluminum front camber block on my 22T. The SCT version has a 2mm higher mounting pad than the 22/22T version along with having mounts for the front sway bar. By running this block you can run up to 6mm total inner height to mellow the steering for when the track gets loose.
#3660
With the 10K it lost a little bit on on power steering but I did not diff out as bad coming into a high speed hairpins.
The high speed turns coming into a hirpin is hwere I could not get teh gear diff to work. I would just loose teh rear end and went back to my ball diff due to this
