TLR 22T Thread
Old 07-02-2012, 01:00 PM
  #3541
did the same with what you posted some days back: http://www.petitrc.com/setup/losi/se...les/index.html
Arn0 is offline
Old 07-02-2012, 02:26 PM
  #3542
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
That's awesome, Thanks!
Frank Root is offline
Old 07-02-2012, 04:33 PM
  #3543
TLRacing
Todd Hodge's Avatar
Originally Posted by vr6cj View Post
Thank you sir! Thats support right there. Just another reason to love TLR.
One thing on his setup? 17.5 oil? Or should that be 27.5?
17.5
Todd Hodge is offline
Old 07-02-2012, 04:44 PM
  #3544
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by T. Hodge View Post
17.5
ok, i get that with those piston size. Now one more. 1 degree camber? Not -1 degree? Seems outta the norm seeing everyone and there brother runs -1.
thanks
vr6cj is offline
Old 07-02-2012, 05:57 PM
  #3545
TLRacing
Todd Hodge's Avatar
thanks
It's most likely -1 and not +1.
Old 07-09-2012, 09:38 PM
  #3546
TLRacing
Frank Root's Avatar
Default New 22T Setup
Hey Guys,
Check out the new 22T setup I got from one of our team drivers, Trever Adamo. I found it to be quite good....
http://losiracing.blogspot.com/2012/...my-22t-at.html
Thanks!
Frank
Old 07-09-2012, 10:39 PM
  #3547
JosephBlack's Avatar
Originally Posted by Frank Root View Post
Hey Guys,
Thanks!
Frank
2 hole 1.7mm pistons Frank? Is that a Losi piston? example 54,55,56?
Thanks!
JosephBlack is offline
Old 07-10-2012, 05:51 AM
  #3548
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Thanks!
i second that, do you have a part number for this piston? What type of track was this med bite, high bite?
MODELTECH22 is offline
Old 07-10-2012, 08:48 AM
  #3549
jkirkwood's Avatar
This was most likely a custom made piston Trever made. It is an interesting setup for sure.
I can't remember if the kit includes piston blanks, if it does just drill two holes. If it doesn't take a 57 piston and fill two holes with glue, and then drill out the two remaining holes at 1.7mm or a #51 sized drill bit which is 1.7018mm in size.
jkirkwood is offline
Old 07-10-2012, 10:10 AM
  #3550
Tony Rivas's Avatar
Trader Rating: 56 (100%+)
love this truck! Cant wait to get mine.
Tony Rivas is offline
Old 07-10-2012, 10:25 AM
  #3551
Thanks for the response Kirkwood, I was just wondering if Losi was making some new pistons for us.
I just got this truck over the weekend and I can't wait to take it out of the box and build it.
Old 07-10-2012, 11:47 AM
  #3552
losi_racer's Avatar
Hey guys,
Looking to buy this truck, I know with the buggy It was recommended to get some alum goodies mainly for weight and also different parts for tuning . I'm at work now or I would do research my self, what is needed for this truck, upgrades and tuning parts thanks
losi_racer is offline
Old 07-10-2012, 01:40 PM
  #3553
RShockley's Avatar
Originally Posted by losi_racer View Post
Hey guys,
Here read this blog. I feel the majority of it holds true for the truck as well.
http://losiracing.blogspot.com/2011/...or-my.html?m=1
RShockley is offline
Old 07-10-2012, 02:16 PM
  #3554
Casper's Avatar
Trader Rating: 34 (100%+)
Yep pretty much.
Casper is offline
Old 07-10-2012, 03:07 PM
  #3555
Trader Rating: 83 (100%+)
Most likely a stupid question but I have the 22t and Viper vtx10 esc/motor combo. I picked up a 17t robinson pinion for it and I can't get the motor close enough to mesh the spur/pinion. I can't slide the motor close enough with both motor screws in is the problem. What am I doing wrong?
bigbeej is offline
