TLR 22T Thread
Old 06-27-2012, 05:53 PM
  #3511
Angry Whaaaaaat!?
Originally Posted by Frank Root View Post
We don't offer any trailing spindles for the 22T. The 4mm trailing spindles are for the 22 buggy only.
AMain as well as others are listing them for the 22T...
I ordered today......
RC Jay is offline
Old 06-27-2012, 10:48 PM
  #3512
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Sorry to hear that bad info is out there, but they will not fit properly, I can confirm that.
Frank Root is offline
Old 06-28-2012, 12:03 AM
  #3513
Trader Rating: 46 (100%+)
Ran the truck tonight for the first time in months...and managed to get 2nd tonight(technically 1st) as the winner was the only mod truck in the class. The truck is awesome I will be trying white rear springs the next time out just for the heck of it..but I am glad I decided to keep it instead of trying to dump it
NitroLuver is offline
Old 06-28-2012, 02:15 AM
  #3514
1bigshane's Avatar
Trader Rating: 18 (100%+)
Hello there!! man this weeks show was cool, www.rcracechat.net had the chance to talk to Jimmy Stephensen with Lucas Oil Off Road Racing and team losi driver.
http://www.rcracechat.net/episodes.html
1bigshane is offline
Old 06-28-2012, 02:31 AM
  #3515
slow_jun's Avatar
Trader Rating: 14 (94%+)
thanks for that, i was about to order that in AMAIN...
slow_jun is offline
Old 06-28-2012, 04:27 PM
  #3516
TLRacing
Frank Root's Avatar
Default 22 vs. 22T Spindles
Hey Guys,
I have had a few questions regarding the 22 vs. 22T Spindles, and I just wanted to set everything straight.
22 Spindles:
Stock - TLR1061 - Plastic/composite molded spindles have 2mm of trail
Option 1 - TLR1062 - Plastic/composite molded spindles have 0mm of trail, otherwise referred to as "inline".
Option 2 - TLR1073 - Aluminum CNC Machined spindles with 2mm of trail.
Option 3 - TLR1075 - Aluminum CNC Machined spindles with 4mm of trail.
22T Spindles:
Stock - TLR1103 - Plastic/composite molded spindles have 0mm of trail, otherwise referred to as "inline".
Option 1 - TLR1109 - Aluminum CNC Machined molded spindles have 0mm of trail, otherwise referred to as "inline".
The 22 and 22T spindles have different bearing spacing that will not allow the 22 axle to fit in the 22T spindle. The 22T front wheel will hit the 22 spindle arm, ball stud, and steering ball cup, so the 22T wheel will not fit on the 22 spindle. I attached photos, with the part number saved in the description.
Attached Thumbnails TLR 22T Thread-tlr1061-250.jpg   TLR 22T Thread-tlr1062-250.jpg   TLR 22T Thread-tlr1073-250.jpg   TLR 22T Thread-tlr1075-250.jpg   TLR 22T Thread-tlr1103-250.jpg
Old 06-28-2012, 09:28 PM
  #3517
nEoNidas's Avatar
Trader Rating: 20 (100%+)
Hey Guys,
22 Spindles:
22T Spindles:
Frank, you're an alright dude. Saving us dumbasses from spending and believing something that just isn't. Saved me some $. Thank you.
nEoNidas is offline
Old 06-29-2012, 12:05 AM
  #3518
Trader Rating: 16 (100%+)
I'm new to the 22T, just traded for one. I see a lot of talk about hop up parts. The car came with the aluminum caster block. I have the aluminum battery bracket and did the 1mm tranny loft. What else helps. Let me say I have a 22 buggy so I understand that set up and time make the car but what hop ups are worth my money.
A929ryda is offline
Old 06-29-2012, 12:56 AM
  #3519
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Other than what you got, you should be good to go. The Aluminum camber blocks fr ar rr are nice though but not totally needed.
thecman26 is offline
Old 06-29-2012, 01:22 AM
  #3520
retsoorkcuf's Avatar
Default 22t rtr esc
Ok my tekin went out so i bought a 22t rtr esc for 30$ and it has a 13turn limit i have a 13.5 i have been running with this esc but my question is can i use my endbell timing or do i have to leave it at 0 will timing adjustment hurt the esc
retsoorkcuf is offline
Old 06-29-2012, 07:38 AM
  #3521
Casper's Avatar
Trader Rating: 34 (100%+)
The rating is a littlle conservative. You should be able to crank the timing on the end bell with no problems if that is what you normally do.
Casper is offline
Old 06-29-2012, 07:48 AM
  #3522
awidz's Avatar
Trader Rating: 15 (100%+)
Default rear tranny raise
i have had my 22t on the shelf since the indoor season ended and wanted to ask how do you do the tranny raise in the rear everyone is doing? any help would be appreciated, i guess it helps keep the rear end more planted.
thanks in advance
awidz is offline
Old 06-29-2012, 07:50 AM
  #3523
Default thanks casper
thanks for the info I have to admit I have been pretty impressed with the losi esc while my tekin is getting repaired
Old 06-29-2012, 08:00 AM
  #3524
jkirkwood's Avatar
I added 30deg aluminum front pivot just for the weight. And the rear aluminum hubs for strength. If you use the aluminum hubs consider titanium ball studs as well in the hubs.
jkirkwood is offline
Old 06-29-2012, 08:45 AM
  #3525
TLRacing
Frank Root's Avatar
You can turn up the timing on the motor no problem with that ESC, there should be no issues at all. Keep an eye on the temps, but the ESC should have no issues.
Not too bad for an "RTR" ESC...huh
Thanks Casper!
