TLR 22T Thread
#3421
The aluminum steering rack can bind. The arm that the steering link attaches to will "lock" on the outer rack while trying to return to center. With a little dremel work you can prevent it. I've been running the same aluminum rack for 6 months now without any problems.
Untwisted the link and the steering no longer binds up. It is a little tight when approaching full lock to the right, but as previously mentioned...the rack should break-in over time.
Check out the Losi blog. Latest entry is a "how to" on adding captured rod ends.
http://losiracing.blogspot.com/
#3423
Best wheel bearings everyone is running or has ran?
#3424
I have had great sucess upgrading to these HD clutch bearings from losi.
http://www.losi.com/Products/Feature...rodId=LOSA6954
#3426
#3429
hi
here is my low cost solution.
I cut several shims from Teflon.
I drive a long time so. does perfectly, with no big play. if too much load, then a thicker Teflon
best regards from italy
dani
dani
#3430
Looking at rebuilding the different for the first time, suggestions on part's?
#3431
BFastRC.com Part #P54-C.
If you clean and re-grease the differential after every 30-45min of track time, then those parts will last a long time. The damage is usually done when running incorrect differential or slipper tension, or putting off maintenance and running the parts dry. When things start feeling gritty replace the thrust washers and diff rings. I've been using the same diff balls since November on my buggy. I only replace the rings every few months.
The TLR22 and TLR22T is very picky on the differential being correct, even more so than the Triple-X series was. If you are unsure how to build one properly have a look at Matt Castellano's video on the subject.
http://www.youtube.com/watch?v=JkJwc_lZbyU
+ YouTube Video | |
Good luck.
#3432
Thought I saw some one post a few months back about their rear springs rubbing on the shock body threads. I've got the same problem all of the sudden with certain springs and I can't find out whats going on. Any one else experience this problem? Solution?
~ J
~ J
#3433
I assume you mean differential.
Good luck.
+ YouTube Video | |
Good luck.
#3434
Good luck.
+ YouTube Video | |
Good luck.
#3435
Everytime I try to install new caster blocks my front suspension starts binding really bad.
What do I do?
Do I have to wait until the new blocks break-in? Do I ream out the holes that the pins go through?
Im trying to go from 5 deg blocks to zero. Are the zero degree blocks are more prone to binding?
What do I do?
