TLR 22T Thread
#3391
#3393
Need help! I am new to this truck and noticed when building it that it has NO servo saver of any kind which I feel is VERY necessary,anyways I broke the slider on the rack from rubbing a PVC pipe.Do you guy's think I should replace with stock rack OR aluminum Rack? what are your experiences?
Thanks,
Thanks,
#3394
Thanks,
Thanks,
#3395
Thanks,
Thanks,
#3396
Thanks Casper! I will go back with the stock rack.I do use a pretty strong servo Futaba 9351.I just grazed the pipe which is black plastic drainage pipe..could have had a nail not all the way through the pipe...
#3397
I have driven the 22 for a long time and never broke a rack. I did break on my 22T but deserved it. I tagged the wall pretty good. Second one has held up great. My point is you may break them but should not be a common thing. That futaba servo is a good one and should hold up great.
#3398
I have a question that may be obvious but just not finding it in here, what does the 30 degree front pivot do for your handling, quicker turning?slower turning? Thanks in advance.
#3399
Thx bnj325. How do you like the gear diffs in the 22t? What is the performance value compared to the ball diff aside from the strength?
#3400
i run stock 17.5 motor...im not a very aggressive driver and have built everything to manual specs. I keep snapping the right rear wheel axle pin. I've replaced it twice and was wondering if there is a fix to prevent it from breaking or an after market pin that i could use.
#3401
#3402
#3403
#3405
Well racing sunday her 22t worked for the 1st 2time qualifiers then in the amain boom stops steering to the right. I run a savox in my ten scte with a spectrum and rx8 and have no issues. Really starting to wish i didnt waste the money on this 22t.
