TLR 22T Thread
Old 06-02-2012, 08:13 PM
  #3376
RShockley's Avatar
It sounds like it would probably be either a wiring or electronics issue. All the things I can think of causing intermittent problems you have check. You might be loosing full power to the servo at some point. I would check all the wiring to make sure nothing is causing a short.
RShockley is offline
Old 06-03-2012, 02:05 AM
  #3377
rider313's Avatar
Trader Rating: 94 (100%+)
Try a differnt servo.
rider313 is offline
Old 06-03-2012, 07:31 AM
  #3378
Ive changed 1 new servo with 125oz for another new servo with 277oz, im wondering if dirt is getting into the rack but then why would it only do it to the right? I love my ten scte but am starting to hate this 22t
randomhero is offline
Old 06-03-2012, 07:35 AM
  #3379
Trader Rating: 30 (100%+)
Try with no shimmed
Otto.951 is offline
Old 06-03-2012, 07:48 AM
  #3380
rider313's Avatar
Is the rack by chance hitting the horn when you turn right? How many shims do you have behind it with the 1251 servo.
rider313 is offline
Old 06-03-2012, 11:06 AM
  #3381
Angry Steering issues.
So swapped out my steering carriers for the TLR aluminum ones and they bind. Found that the spindle is not holding the pins straight so when you screw them all the way in, the spindle does NOT move freely. Put plastic back on and the move fine but all that slop is back.
Did you check you carriers?
RC Jay is offline
Old 06-03-2012, 02:37 PM
  #3382
bigfred819's Avatar
Trader Rating: 45 (100%+)
Savox and Spektrum together are a bad combo from what I have seen and heard. It's one of the reasons I only run Futaba gear.
bigfred819 is offline
Old 06-03-2012, 04:22 PM
  #3383
rider313's Avatar
Double post.
rider313 is offline
Old 06-03-2012, 04:28 PM
  #3384
rider313's Avatar
I ran spektrum and savox for over a year without an issue. It all depends on the brand of speed controle you run if you need a glitch buster or not. And with the viper system he has he does not need a glitch buster. In all my viper powered cars I have savox and have no busters and all preform perfectly.
If your statement was true even spektrums own servos wouldn't work with there cars, for they are made by savox. I hope that wasn't the only reason you went away from spektrum when your esc was at fault.
rider313 is offline
Old 06-03-2012, 04:43 PM
  #3385
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by rider313 View Post
If your statement was true even spektrums own servos wouldn't work with there cars, for they are made by savox. .
Not sure were you got your info but that is false .
Briguy is offline
Old 06-03-2012, 05:29 PM
  #3386
rider313's Avatar
Ok maybe made by is the wrong wording, however they are basicl the same. The gears from my savox 1258 fit in my spektrum 6040. They are almost identical. A local also put the low profile servo gears from spektrum in his 1251 savox.
rider313 is offline
Old 06-03-2012, 05:55 PM
  #3387
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
This is good news, because ThunderbirdJunkie just bought some 6070 gears for his 1251.
T-BirdJunkie is offline
Old 06-03-2012, 09:38 PM
  #3388
Does anyone run the gear diff instead of the ball diff? If so how do u like it and what diff fluid are u running? I run at an indoor clay track and like the less maintenance and strength of the gear diff.
Borik is offline
Old 06-04-2012, 08:07 AM
  #3389
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Are you running the threaded kingpins? This should make the fit better.
Frank Root is offline
  #3390
bnj325's Avatar
Default 22t
I only run gear diffs indoor I run 2000wt and outdoor I go up to 5000wt.
bnj325 is offline
