TLR 22T Thread
#3349
My truck was loose out of the turns ....raised trans 1mm and now is very predictable coming out of corners under power
#3351
I did that and went to yellow buggy rear springs
#3354
Here is my setup sheet Stock Nats for the 22T. I had a real shot at this race but made a bonehead mistake on the second lap
With this setup I ran a 10 minute main at OCRC and came off at about 140
http://www.tlracing.com/ProdInfo/Fil...ck.%20OCRC.pdf
If you guys want to run a full pack go to yellow buggy rear springs in the front and take 1 coil off of them, also go up 2.5 wt in the rear and use 1 foam block in the back instead of 2. This is what I run for mod as I feel its easier to drive with a big pack when it has tons of motor. But for stock I like the shorty
#3355
there is a user on the site, gone banana.....he makes foams...
#3360
Yes the truck springs can rub a little bit. Buggy rear sprins do not rub for they have less coils to stack up.
