TLR 22T Thread
#3331
New to the 22t, bought it used of an rctech member. I'm having issues with the steering rack binding. It came with the aluminum rack. I thought it was a servo issue. I've had the front end apart a few times, even a little lube to help smooth it out, still binding. Just looking for a little guidance. Thanks.
#3333
What are you guy's doing about the front rims rubbing on the steering ballcups?
no matter how much I back off the wheel nuts the rims still rub,I have tried shims between the plastic hex and rim this will not work because there is not enough trheads to hold the nut on the axle.this is the only flaw I see with this truck,and we all know there is NO wheel that has 0 wobble to it...lets here some answers ??
#3334
Also I run my nuts super tight and dont have any bind issues.
#3335
Thanks,I have noticed my stock UNUSED wheels have more wobble than the usual,I will race this truck for the 1st time tomorrow nite.it has the stock kit set up,I did raise the trans up 1mm and went to 4 rear toe because I have read a few post that people claim the rear needs to be locked in alittle more..
#3336
#3338
Suspended
#3339
Suspended
#3341
Has anyone ran the proline scrubs yet? Opinions? Most common tires at my track are suburb style as soft as possible. Was going to get a set and try but figured maybe someone would have some input
#3342
#3343
The 1mm trans lift....
About that 1mm trans lift that seems to becoming the norm... Anybody have some solid results on that? Notice a difference? How much of what?
#3344
I hope pro-line is in the process of making a bulldog body for the Losi 22t,we don't have much choices in a desent body.the stock body is waaaaay to thin/brittle...just my .02..
#3345
i think one of the team guys here has noted that the alloy rack binds, but I bought one and worked on the plastic guide it slides in for a while with some fine grit sandpaper before remounting in the truck to smooth out the edges and got rid of the binding and notchiness others have noticed. took a little time, but was worth the effort.
