TLR 22T Thread
Old 05-20-2012, 11:41 PM
  #3316
RShockley's Avatar
I am just hoping the class doesn't completely die out here. I have really enjoyed running the truck since I got it.
RShockley is offline
Old 05-21-2012, 09:46 AM
  #3317
Trader Rating: 99 (99%+)
I'd like to know is a Savox SC-1258 servo sufficient for a 22t ?
isarctard is offline
Old 05-21-2012, 10:08 AM
  #3318
Casper's Avatar
Trader Rating: 34 (100%+)
Yeah plenty of servo.
Casper is offline
Old 05-21-2012, 10:09 AM
  #3319
The Juice's Avatar
Trader Rating: 25 (100%+)
Absolutely, I have heard some say its more than enough.
The Juice is offline
Old 05-21-2012, 12:17 PM
  #3320
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Awesome body.
I'm putting my ST back together tonight.
t0p_sh0tta is offline
Old 05-21-2012, 01:46 PM
  #3321
Trader Rating: 15 (100%+)
Originally Posted by cola View Post
Does anyone know of a company making boots for the CVA's?
Durango's CVD boots fit my 22, so they should fit the 22T - same goes for their outdrive boots.
HeavyD99 is offline
Old 05-21-2012, 01:53 PM
  #3322
t0p_sh0tta's Avatar
The Durango boots fit just about every 1/10 scale car out there. I run the inners and outers on my 22T as well.
Old 05-21-2012, 06:02 PM
  #3323
rider313's Avatar
Trader Rating: 94 (100%+)
Some on board of the 22T at the race last weekend. Went on to take second in the A main.
+ YouTube Video
Link for the IPhone guys
rider313 is offline
Old 05-21-2012, 06:37 PM
  #3324
Grandturk's Avatar
+ YouTube Video
Nice! And thanks for the "iFriendly" link!
Grandturk is offline
Old 05-23-2012, 11:45 PM
  #3325
Here are a couple shots of my 22T from last weekend at JBRL
This truck has become my favorite car I own.
Silver04RS is offline
Old 05-23-2012, 11:50 PM
  #3326
Cloaked's Avatar
Im running a 1257TG in a SC10RS and its way more then enough.
The 1258 has more torque, trust me its plenty of steering.
Cloaked is offline
Old 05-24-2012, 04:32 AM
  #3327
slow_jun's Avatar
Trader Rating: 14 (94%+)
More than enough,so go pull the trigger :-) .
Using one on my 22T. :-)
slow_jun is offline
Old 05-24-2012, 08:20 AM
  #3328
Originally Posted by PnchoPwr View Post
I'm having trouble keeping the toe link ball cups on (on the wheel side). I barely clip a pipe and the things seem to pop off. Replaced them with new, same problem. Anyone else having this problem, if so, what are you doing to fix it? It's cost a me a couple of A main wins so far.
Also, not looking for the "don't clip the pipe" response. Thanks in advance.
As someone already mentioned, you can use the aluminum hexes. I had some issues just as you did, I put the aluminum std. width hexes on and I have not had an issue since. I don't think you need the wider hexes in alum to aid this.
hope this helps.
Leon
punkracer24 is offline
Old 05-24-2012, 08:55 AM
  #3329
Casper's Avatar
We have found the SCTE alum hexes will fit on the front of the 22T. You have to shim between the bearing and roll pin though. I can't remember right now how much I used but basically you want to take up the space between the roll pin and bearing. Just take out the slop don't make it shimmed tight or you will bind the bearings. Kyosho has some shims that work great for this.
http://www.losi.com/Products/Feature...rodId=LOSB3493
http://www.amainhobbies.com/product_...5x7mm-Shim-Set
Casper is offline
Old 05-24-2012, 10:19 PM
  #3330
wrightcs77's Avatar
Trader Rating: 549 (100%+)
Looking for some shock advice. Does running emulsion style shocks make them feel "softer" than running with bladders, all other things remaining the same?
wrightcs77 is offline
