TLR 22T Thread
#3002
So i was extremely lucky yestaurday and won a 22t from The TLR shootout at my LHS and was wondering a few things before i go buy somethings for it. I run a Team Orion 6500 in my SCT, is this a good battery for this or a little over kill. I geuss just anything, like what to stock up on or just start with the normal things that brake most. A-arms, hubs and so on. I see Casper is on here also so i can bug him for set up help on 2 threads
Thanks in advance for any and all input.
#3003
#3005
How too calibrate your lrp to your radio
Connect the speed-control to the battery and switch the unit on.
Hold the SET button pressed for at least 3sec.
You entered setup mode and the SET LED flashes blue (it will flash until the setup is completed).
Leave transmitter in neutral position and press the SET button once.
Neutral setting is stored , MODE LED flashes yellow and the motor beeps.
Hold full throttle on transmitter and press the SET button once.
Full-throttle setting is stored, MODE LED flashes red.
Hold full brake on transmitter and press the SET button once.
Brake setting is stored, LEDs glow red (MODE) and blue (SET).
make sure you set your epa's to 100% on your radio
#3006
hey everyone wondering if i can get a little advice.Im running stock 17.5,with the timing on the motor turned up a little passed center,and nothing in the speedo,Im geared at 76 28 for a indoor clay track....westcoast raceway,and im coming off the track close to 185 degrees for a 5 min main....wondering why its getting so hot? Also I use those protek 70 c 6400 mah batteries,and I notice that after about 5 laps I dont have the same punch as from the start,could it be these batteries,or that the motor is getting so hot that is loosing a little power?
#3007
Yes its possible with a low profile servo. I used a Futaba S9551, had to mount the Rx on top of the servo and basically place the battery foam on the back of the servo to hold the battery in, 5000mah Orion stick pack. It worked, accelerated well and turned great, but couldn't accelerate and turn to keep up with the rear motor set-ups. So it only lasted one race night.
#3008
#3011
Considering getting back into racing and like the 22. What would you think of buying the RTR version and racing that? It kind of feels like cheating to me, and in my 23 year involvement in the hobby, I've never purchased an RTR, unless a kit form was not available (i.e. TMAXX, Mini X).
How is the build quality?
I'm just super short on time (and patience
#3012
#3013
The kit has higher quality of components in it than a rtr does. Keep in mind, with an rtr they have to keep the price similar to other rtr products on the market therefore there are some differences between the two products. However, I have seen quite a few rtr's out racing on the track and they appear to be holding up just fine.
#3014
The TLR 22T is very easy to build, the only rtr version of vehicle I bought was a Revo 3.3 and after the first run felt the need to rebuild with every hop-up under the sun. So RTR to me is not the best investment, the electronics and factory set-up I my mind leave a lot for a racer to build on in the RTR. I suggest keeping your eye peeled for some deals that come on the board and you might get a trick truck for around the price of a RTR but with the gear you want. Either way your set! Have fun tearing it up!
#3015
