TLR 22T Thread
#2761
Lunsford Super-Duty turnbuckle and ball cups fit right on the 4.8mm Losi ball studs and will solve all your popped ball cup woes.
http://www.amainhobbies.com/product_...-w-Ball-Cups-6
I have yet to pop one in months of running them on my DESC, a much faster and heavier car than a 22T.
#2763
thanks
#2765
for the turnbuckles take them appart and AE makes some stuff called Green slime put a little in the ball cup before you put it back together then hold the ball cup with a pair of pliars and run the tie rod all the way in. That way you will have threaded it all and it will adjust with ease and not keep poping off.
Jeremy
Jeremy
#2768
MC Suburbs all the way around with stock foams.
I was running pink BK Bars, but can't get my hands on any more. This is my first time running Proline's MC compound on a hard packed, indoor track with med bite.
I love it. Steers for days and will pull wheelies on command. Plus they wear better than BKs do.
#2770
keep popping ball cups even with slight rubs, any ideas? i even put the 22 buggy rear hexes on the front but did not help. does anybody make better ballcups? like rpm ect. any help would be appreciated,love the truck but popping ball cups every race is getting old, if i cannot find a fix might have to find a different truck. any help would be appreciated
thanks
thanks
Kyosho cups
but for mine, i havent encountered any popping of cups. YET. but you may want to lossen up on the nut, once you feel its hits the last turn, then you want to stop Tightening the nut.
#2775
Just a little FYI, raced this weekend for the first time with the new truck, and it handled like a dream i had a little issue landing and my rear end kicking up but it was resolved imediatley by turning out the shock ends 2.5 turns, beat two kyosho's to take the top spot....great work TLR!!
