TLR 22T Thread
#2551
Anyone else ran mid motor?
#2552
Jenzo , there is a mid motor thread floating around somewhere that has a lot of good info . LCJ`s must have some insane traction
Edit *
Found it !
http://www.rctech.net/forum/electric...2t-thread.html
Edit *
Found it !
#2554
I just thought I would throw out one thing...if you are running my setup in stock, I tested some this weeeknd and I would go to 27.5wt oil in the rear and add 2 turns of droop to the rear.
#2555
#2556
Edit *
Found it !
Edit *
Found it !
#2557
I have the brass weight system for rear motor on the 22 buggy, I was thinking of using the other 7g weight on the 22T, I'm currently running the kit setup only thing I changed was 2mm washer on the inner front link positon and I'm running 1B instead of 2B in the rear. I race on a smooth med bite track about 90x50 and the truck feels good I was just curious if anyone running on a similar track has tried adding weight to the rear of the truck and what was the result?. I'm gonna be running the 30deg aluminum front pivot and aluminum front camber mount and wondering if I should add the 7grams to the back?.
#2559
I thought about what you were saying but, figured if I cut it there is no way to fold the cut area and have it line up and still seal properly than just taking the extra 2sec to open and drop it on the posts.
#2561
#2562
A little more secure than just the flaps.
See for sale thread in sig. \/
#2565
Yes, I added weight to mine and it was incredible, but I added 1 ounce overall to the rear, 1/2 oz under the shock tower on that nice flat spot and 1/4oz on each side of the chassis as far back as I could fit them. Made it nice and stable and brought the rear traction to lockdown state like my old RT5 was. Maybe even better that it (RT5) was...
