TLR 22T Thread
Old 02-21-2012, 12:08 AM
  #2476
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by Dougoilman661 View Post
well ill give it a go and see how it turns out. I appreciate your input
No problem!
thecman26 is offline
Old 02-21-2012, 01:31 AM
  #2477
Trader Rating: 206 (100%+)
Has anyone tried the 22T wheels onto the XXXT?
dodgeguy is offline
Old 02-21-2012, 09:40 AM
  #2478
cola's Avatar
Trader Rating: 308 (100%+)
The offeset isn't right and the hex size on the xxx wheels is too big.
cola is offline
Old 02-21-2012, 02:06 PM
  #2479
Suspended
Trader Rating: 39 (96%+)
does anybody know if the gearing chart in the 22t book is right? if not how would i gear my 22t with a 17.5 no boost and with a 8.5 and 13.5
JOSH MILLIREN 1 is offline
Old 02-21-2012, 02:15 PM
  #2480
Casper's Avatar
Trader Rating: 34 (100%+)
The manual is a little conservative. I would start with 29/78 for NT stock. 13.5 probably a 25/78 is a good start. I have to look back to see on the 8.5.
Casper is offline
Old 02-21-2012, 02:17 PM
  #2481
Trader Rating: 75 (100%+)
I been running 23/78 8.5 very quick.
Chase1472 is offline
Old 02-21-2012, 02:48 PM
  #2482
Grandturk's Avatar
What's the deal with people using The plastic RTR shock caps? What are they using them for? What's the advantage? The only difference I see is that they seem to come with o rings?
Grandturk is offline
Old 02-21-2012, 03:04 PM
  #2483
e_lu_sive1's Avatar
dont u need those o rings for the front of the shock shafts?? they don't tell u that in the manual supposedly idk I'm learning myself..
e_lu_sive1 is offline
Old 02-21-2012, 03:10 PM
  #2484
Grandturk's Avatar
No i'm talking about the top caps not the bottom caps.
Old 02-21-2012, 03:11 PM
  #2485
The plastic caps have bleed holes in them. That makes it easier for some to bleed the shocks quicker. That way it's easier to get same amount of rebound for each shock.
kstoracing1 is offline
  #2486
The RTR caps have bleeder screws which makes building the shocks quicker and easier. I use them on my son's 22 and 22T just to make maintenance easier/quicker and more consistent.
Between the 2 of us we run 7 cars, so anything that speeds up maintenance helps.
Bike racer is offline
Old 02-21-2012, 03:16 PM
  #2487
Casper's Avatar
They have a bleed screws instead of just a small hole in the side of the cap. The bleed screw helps make it much easier to get consistantly bleed shocks. the stk alum caps are alright but takes a little more patience to let the oil bleed out the side.
Casper is offline
Old 02-21-2012, 03:17 PM
  #2488
monty c's Avatar
Location: Dont get any more northwest than me..........
People are running the RTR caps so they can run the emulsion shocks instead of the stock bladder shocks. When the 22 buggy came out people found they liked the emulsion better than the bladder style. They were cutting the centers out of the bladders. With the RTR caps there is no more chopping up good bladders.
Also the RTR caps come with a bleeder screw making bleeding shocks a breeze. They are well worth the money. Shocks are a lot better with them in my opinion.
monty c is offline
Old 02-21-2012, 04:36 PM
  #2489
It gets easier. It unfortunately is an experience and feel thing. Once you understand what a good starting point is for feel it gets a lot easier.
This is very true. I've noticed that even having been out of the game for several years, every time that I've changed out the spur gear, I somehow tightened the slipper down to nearly the exact right position! I remember back in the day getting it on there and having the thing slip halfway down the straight, having to pull it off the track, adjust, and go again... but now for some reason I am able to get it right by feel. My diff was the same way. I built it, tightened it down, and haven't had to adjust it once... or maybe I just don't know what it is supposed to be so it seems ok even though it isn't?
chadmart is offline
Old 02-21-2012, 08:05 PM
  #2490
tfrahm's Avatar
Originally Posted by Peff View Post
Is it just me or has some virus or ghost taken over this website.
Not sure if this is what you mean, but everytime I change to the 'print' view, my computer's virus protection goes WILD screaming about potential security threats... Strange....
The page you are trying to access has been identified as a known exploit, phishing, or social engineering web site and therefore has been blocked for your safety. Without protection, such as that in the AVG Security Toolbar and AVG, your computer is at risk of being compromised, corrupted or having your identity stolen. Please follow one of the suggestions below to continue.
URL: simbeppc.com/jscript/pixel.js
Name: JavaScript Obfuscation (type 156)
tfrahm is offline
