TLR 22T Thread
Old 02-05-2012, 02:40 PM
  #2206
GeorgePravata's Avatar
Trader Rating: 136 (100%+)
So the rears of the 22t are longer then the rears on the 22 buggy Thanks
GeorgePravata is online now
Old 02-05-2012, 02:58 PM
  #2207
Grandturk's Avatar
Got an old JR servo - 80 oz torque and .15 speed... I'm just joking with that servo for this truck right? I shouldn't even think about it right? I should just get a Savox 1257 or 1258, right? I shouldn't even test the truck out with that servo right?
Grandturk is offline
Old 02-05-2012, 03:02 PM
  #2208
shlupy22's Avatar
Trader Rating: 6 (88%+)
Originally Posted by hacker07 View Post
To those with the front wheel rubbing, the front hexes are a softer material and thus you want to snug down the front wheel nuts, preferably get serrated ones, but DO NOT overtighten them. This will cause them to rub and thus your truck wont handle as well.
i am not sure what the roar legal width limit for the front of stadium truck is, but i took traxxas slash hex's and put them on the front of my 22t and it creates a very small gap between the rim and the ball cup, it works pretty good, but like i said i dont know if it is roar legal or not yet
shlupy22 is offline
Old 02-05-2012, 04:36 PM
  #2209
that is up to you.........it will test it out just fine but i would plan on changing it at some point. all depends on how anxious you are and if you feel like replacing the servo or waiting.
sjenkins97 is offline
Old 02-05-2012, 05:46 PM
  #2210
Toiffel's Avatar
Trader Rating: 52 (100%+)
Finally had a chance to try out the 22t and had a blast, haven't made any changes yet from stock set up, but out of the box it was so much fun and easy to drive!!
Toiffel is offline
Old 02-05-2012, 05:47 PM
  #2211
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Just for a heads up, there are people in the for sale section with some good deals available on good high quality servos...
thecman26 is offline
Old 02-05-2012, 06:13 PM
  #2212
bombertodd's Avatar
Do you know how much wider the traxxas slash hex's are? Sounds like a good idea.
bombertodd is offline
Old 02-05-2012, 06:16 PM
  #2213
Briguy's Avatar
Trader Rating: 125 (100%+)
I been running the stock setup and was amazed how good it is .
Briguy is offline
Old 02-05-2012, 07:00 PM
  #2214
yodace's Avatar
Is there anything I can do to the turnbuckles/ballcups to make them easier to adjust instead popping off?
yodace is offline
Old 02-05-2012, 07:03 PM
  #2215
Grandturk's Avatar
I always use a bit of Chapstick when threading turnbuckles into the ends. Works great nice and easy to adjust and they never stick. Keep a tube in you're pit box.
Old 02-05-2012, 07:10 PM
  #2216
thecman26's Avatar
A touch of black grease on the turnbuckle then thread on the ball cup = smooth as butter!
Old 02-06-2012, 08:19 AM
  #2217
Peff's Avatar
Default Savox servo shims
Hey guys,
Finally got this Beaty this afternoon and rushed home to build.
What's size shims do you use for savox servos? Do they use a 25 servo horn?
Peff is offline
Old 02-06-2012, 08:21 AM
  #2218
rob martin's Avatar
Trader Rating: 62 (100%+)
Originally Posted by Peff View Post
Hey guys,
Yes the 25 horn and if your running a 1258 i used no shims.
rob martin is offline
Old 02-06-2012, 09:07 AM
  #2219
Peff's Avatar
Thanks rob, I am using a 1258 tg
Peff is offline
Old 02-06-2012, 09:11 AM
  #2220
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I would suggest around 150oz and up, and .10 speed or faster to be ideal. The Spektrum SS6040 will meet both of these specs and is a very competitive price.
http://www.horizonhobby.com/products...peed-SPMSS6040
Frank Root is offline
