TLR 22T Thread
#1907
Will part: Team Losi Racing Aluminum Rear Hub Set (TLR 22) [TLR2057] fir and work on the 22T?
#1908
The spacer is in there for changing between inline spindles and trailing spindles. The buggy comes with trailing which is why it is behind and the truck comes with in-line which is why it is in front. Since the wheel indexes to the spindle the location of that spacer has no effect on the steering arm clearance to the wheel. The spacer just moves that whole caster block/spindle/wheel assembly back and forth.
#1909
ryan,
will these fit on the front on the 22t? or the thicker ones for more off set
http://www.amainhobbies.com/product_...d-Width-TLR-22
#1910
I run at the Hobby Town in Lake in the Hills. There are a couple of us that run the 22T up there. I'm gonna start changing the setup on it today when I get to work. Gotta loosen up the rear end a lot.
#1911
My ball cups keep popping off is there an upgrade?
#1912
Hey guys,
I'm still waiting for my truck to arrive. Has anyone tried it in dry loose conditions? Any suggestions for setup or tires? I'll start with a stock setup and then try Frank and Dustin's setups. I tried out a friends xxx t and love the stadium truck. Can't wait for my 22T
And it's Ducati paint theme
#1913
#1914
It has been a little while since I touch a SS panther tire but I would say M4 is a little softer.
I tried inline on my buggy and it was way switchy.
The TLR ball cups are some of the best out there. Which one you have poping off? Only ones I have had come off were front inner camber links and that was after a hit on another car I though should break something and only a ball cup that popped right back on.
#1916
#1917
ryan,
#1918
#1920
I would have used it as a starting point but the dirt is VERY different so I figured a few changes would be necessary. Feels like the proving grounds...LOOSE AS HELL...
