TLR 22T Thread
Old 01-23-2012, 03:11 PM
  #1861
Trader Rating: 77 (100%+)
Originally Posted by tedstryker View Post
0 degree caster blocks should improve turn in?
I was having problems with turn in too. Stood the front shocks up one hole at the top and I had gobs of turn in
Wease is offline
Old 01-23-2012, 03:24 PM
  #1862
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by AC Driver View Post
Ryan, Casper or Frank,
Any plans on alum front and rear wheel hex parts like the buggy has?
The aluminum 'standard' offset does work on the front. use solid axle pins.
Fabulous is offline
Old 01-23-2012, 03:27 PM
  #1863
Fabulous's Avatar
Originally Posted by hacker07 View Post
There is no aluminum hex at this point that is the same as the front or rear of the 22T hex sizes. The standard rear are wider that the 22T front hexes.
Its a tad bit wider. Should work on keeping the ball cup away from the rims when Wilde likes to wrench on them.
Fabulous is offline
Old 01-23-2012, 03:35 PM
  #1864
Have not noticed the rub or even feel like it is going to rub on the wheel. however i have notice the turnbuckle being very close to the spring, almost rubbing material.
Couple of minor details in my kit.
1 bent front camber link straight out of the box. minor tweak but it is definitely not straight.
short front battery trey holder and velcro straps. (finished the build as i had a plastic holder from my 22 (which has the alumn. trey now) and i can come up with a velcro strap as well..... otherwise great build, fit and finish. nice job TLR!
sjenkins97 is offline
Old 01-23-2012, 04:11 PM
  #1865
Its wider and the pin to bearing step is different.
hacker07 is offline
Old 01-23-2012, 05:41 PM
  #1866
Trader Rating: 46 (100%+)
what would you guys suggest for 7.5T gearing wise?
NitroLuver is offline
Old 01-23-2012, 06:05 PM
  #1867
Trader Rating: 25 (100%+)
I finally got the time to finish up my side pods and the rest of the truck. I just need to paint the shell. But for right now I'm using my old XXX-T JConcepts body. It fits, just needed to drill new holes. There are a couple of other things I want to do to clean it up. But I can do those later, I just want to be able to get it on the track Friday night.
Mitten is offline
Old 01-23-2012, 06:14 PM
  #1868
lewis4x4's Avatar
Will the "Team Losi Racing Aluminum Rear Hub Set" for the 22 work on the 22T? Part #TLR2057
lewis4x4 is offline
Old 01-23-2012, 06:30 PM
  #1869
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by Toiffel View Post
Need some help guys, I finished building my 22T and can't wait to hit the track, but was so excited about the build I forgot to make a template of the chassis, I have some real nice dirt bike grade clear vinyl for protection that I can't use now, I would more than willing to send one to the person that can supply me with the template (not only outline-need holes for the screws too) please pm for info...
Thanks in advance....
I have the template in my computer for my vinyl cutter . I did not make with the holes as I figured if/when I need to get at a screw I can cut the hole with a e-xacto . PM me
Briguy is offline
Old 01-23-2012, 08:08 PM
  #1870
Yes, the aluminum rear hubs are the same for both.
hacker07 is offline
Old 01-23-2012, 09:38 PM
  #1871
easye's Avatar
tufferwilde
I noticed this as well on mine. The ball cup rubs on the outer circumference of the wheel (no on the inside of the hoop) while running. Wheel is straight when spun.
I will take a photo at lunch and post it. I noticed it after the first run. No noise, doesn't seem to adversely impact handling, just a rub mark from the ballcup.
Chris Wilde
I put .06 shim betwwen the the outer bearing and and the pin for the hex in front no more binding when tightened down and also add .01 shim on the rear hub bearing and drive pin for the hex. im using serrated wheel nuts. part # kyo 96643 (5x7mm shim kit)
easye is offline
Old 01-23-2012, 11:03 PM
  #1872
easye's Avatar
18 or 19 pinion
easye is offline
Old 01-24-2012, 12:38 AM
  #1873
Roger's Avatar
These trucks are dialed at my home track ( NorCal Hobbies ). Might have to get one
Roger is offline
Old 01-24-2012, 06:54 AM
  #1874
Toiffel's Avatar
Trader Rating: 52 (100%+)
Anyone know the part # for a clear rear motor body ? Need a spare one until my painter works his magic....
Toiffel is offline
Old 01-24-2012, 07:01 AM
  #1875
rob martin's Avatar
Trader Rating: 62 (100%+)
TLR8058
rob martin is offline
