TLR 22T Thread
Old 01-13-2012, 11:02 AM
  #1486
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bombertodd View Post
Frank, when will the Ti turnbuckles be released?
They are in stock now.
TLR6068
Casper is offline
Old 01-13-2012, 11:29 AM
  #1487
johnny boy's Avatar
Trader Rating: 311 (100%+)
can somebody tell me the best way to build and bleed the shocks without bladders? I keep bleeding them but seems like there is still air in them??
thanks for the help
johnny boy is offline
  #1488
there will always be air in an emulsion shock
BillySnarf is offline
Old 01-13-2012, 11:37 AM
  #1489
Casper's Avatar
thanks for the help
Get the RTR shock caps. Best money you will ever spend on a set of shocks. Bleeding is not only way faster but much more consistant!!!!!!
Casper is offline
Old 01-13-2012, 11:39 AM
  #1490
fullsyzz's Avatar
Trader Rating: 111 (100%+)
thanks for the help
Hey Johnny, here's a good vid on building TLR shocks with cut bladder.
http://www.rccaraction.com/blog/2011...om-mike-truhe/
fullsyzz is offline
Old 01-13-2012, 12:49 PM
  #1491
johnny boy's Avatar
awesome thanks for the help guys.
Old 01-13-2012, 01:08 PM
  #1492
Trader Rating: 23 (100%+)
maybe asking a dumb question but the tabs on the bottom of the body are they cutting them off or leaving them on?
controlledchaos is offline
Old 01-13-2012, 01:36 PM
  #1493
sparkwraps's Avatar
After painting the body, give the fold of the tabs a bit of a squeeze and they will easily stay at 90º up and out of the way. I didn't cut them at all, but did paint them as if they were part pof the body and looks pretty good.
sparkwraps is offline
Old 01-13-2012, 01:41 PM
  #1494
Casper's Avatar
They were intended to stay but not required. If you don't like them you can cut them off. Team guys were running them both ways as some of the early bodies for testing did not have the bottom part.
Casper is offline
Old 01-13-2012, 02:27 PM
  #1495
MentalWhiplash's Avatar
Default Errors in build manual
Is there an errata online somewere with errors/corrections for the build manual? I've discovered a couple and don't want to forward them if they're already posted somewhere. Some are obvious but there are folks that can't stray from a formula. For example: Step A-6 (attached). Should be as marked, or parts list on left has count wrong.
MentalWhiplash is offline
Old 01-13-2012, 02:31 PM
  #1496
i was wondering how a metric ballstud was going to thread into a standard nut.............hahahahahaaaaaa
clintscreations is offline
Old 01-13-2012, 02:41 PM
  #1497
Trader Rating: 52 (100%+)
Cant wait to start the build
RB5SP is offline
  #1498
Casper's Avatar
Huh. That ball stud in error goes into plastic.
Obviously an error. I know Ryan and Frank are on here. If you PM either one they will get anything you found to the right person to fix in future kits.
Casper is offline
Old 01-13-2012, 02:47 PM
  #1499
Will do...the parts are right on the kit, and the list on the left, just wrong in the illustration.
Old 01-13-2012, 02:51 PM
  #1500
Casper's Avatar
Losi works hard to catch stuff like that but when you are familar with the parts it can be really easy to over look that stuff even when you are looking for it. I was just building my truck last night and blew right over that. I just picked up the parts and built away but I am used to working on my 22 so I already know what goes where.
That section right there is pretty important as you don't want to mix up the 4-40 ball stud with the 3mm ones! good catch.
Casper is offline
