Novak Ballistic 8
Has anybody else noticed this yet?
http://www.shopatron.com/products/pr...0.0.0.0?pp=10&
It looks nice!
It looks nice!
Most of the 1/8th scale applications will use a longitudinally Mounted motor which even with being in the car you will have air holes in the body that will better use that airflow. I can see a cooler in the future that would mount to the rear to glow air across the motor to keep height restrictions low.
Where's the esc to go with it? I hope they make one on par with the RX8.
anyone using this motors? im interested in 1950kv?
I have been running the y wrap for almost a yr now. I was able to get one before they were released. I run it in a losi 8ight with a rx 8 on 4s. It is super efficient , great run times and is happy as a clam coming off at 170-180 all day long. Bearing life has been a non issue, smooth as silk like all novaks sensored motors are. Only issue was trying to fit it into my tekno motor mount. It was a no fit due to the larger mount tunnels for the end bell screws. Fits fine in the losi mount.
This the best working 1/8 scale motor I have run, the castles 2650 is a caveman brute lots of power but not smooth or fully useable, the tekin was close , but could not handle the gearing and came off too hot and showed early bearing wear.
the ballistic is the bomb.
old & slow
old & slow
