1700kv on 4s mbx6 t
Old 07-24-2011, 10:44 AM
Default 1700kv on 4s mbx6 t
Guys, is it enough to run with nitro? Or do I need 5s lipo?
It's got enough torque but lack top speed. I think I am using 16t and stock spur.
Any advice welcome
muaythai is offline
Old 07-24-2011, 11:20 AM
blade329's Avatar
Trader Rating: 114 (100%+)
Any advice welcome
What's the track size? I've seen guy at Revelations (Large outdoor) run 1700kv on 4S and do fine.
blade329 is offline
Old 07-24-2011, 11:21 AM
Default K
As a medium rate racer. About 41 seconds around
muaythai is offline
Old 07-24-2011, 11:46 AM
blade329's Avatar
That's big. I would gear up for more top end, or run a 1900kv. 1700kv on 5S might be okay, but it's going to scream. Might be too much.
blade329 is offline
Old 07-24-2011, 11:48 AM
Pulse_'s Avatar
What motor is it exactly?
Pulse_ is offline
Old 07-24-2011, 11:52 AM
try taller gearing
JeredR is offline
Old 07-24-2011, 01:18 PM
Default K
Tekin.
muaythai is offline
Old 07-24-2011, 01:32 PM
Pulse_'s Avatar
Tekin 4030 or 4038?
Pulse_ is offline
Old 07-24-2011, 01:53 PM
Krio's Avatar
Trader Rating: 152 (99%+)
I am running the exact setup you are asking about. With 3.3 ratio diffs, I'm typically geared 17/46 but have gone up to an 18 on occasion. I only throw my 1900 in if the track is large AND is high traction. As long as you are under 160 after running 10-15 minutes gear up.
Krio is online now
Old 07-24-2011, 10:52 PM
Default Thanks
I see, I might try Robinson 19t then as I feel I got a lot of bottom end but no top end. What batteries u using?
muaythai is offline
