need help choosing 17.5 motor
Hi i have losi 22 and i need help choosing motor. Im planing on buying
lrp sxx v2 esc and im not sure on wich 17.5 motor please help
i have on my list
Trinity DUO 3 Brushless Motor 17.5T
Tekin 17.5 line Senso Brushless Motor
http://www.rcplanet.com/Trinity_DUO_...tritep1053.htm
or
http://www.rcplanet.com/Tekin_Redlin.../tektt2251.htm
Thanks for all help
i have on my list
or
Thanks for all help
i have on my list
or
Thanks for all help
i have on my list
or
Thanks for all help
If your going to ever do a non timing class theres only 1 choice
ICON Version 2... hands down the fastest non timing class motor there is
Boosted or Non-Boosted Go with the Duo 3
The New Team Epic ReVtech motors will be coming out soon as well which are going to be a really big hit!
can the Duo 3 17.5 handle an sc10?
Of course. I saw a regular 540 sized 7.5t D3 pushing around a SC10 4x4 the other day. Tons of power, got second in the main and then came off at 135 degrees, craziest thing I've ever seen.
But the regular 17.5 should work great, if you want more torque they sell a high torque rotor for about $25 that should help with that. Although I'm running the stock rotor in my SC-R and love it.
Thanks guys for all replies
How big of diffrents between this two esc?
http://www.amainhobbies.com/product_...K-III-Firmware
http://www.amainhobbies.com/product_...-Brushless-ESC
The stock spec is going to work better for stock motors providing more boost and turbo functions. Good for stock classes that allow you to boost the motor. The LRP speed controls are very smooth, although if you're looking for lots of boost and all that then the Tekin RS is the way to go, plus it's cheaper.
i have tried a bunch of different 17.5's and my favorite is the orion 17.5 with the timing on the can all the way up. Stock timing seemed like a turd, but as you increased the motor timing the motor really came alive. I haven't personally tried the tekin motor but i have tried almost all of the ones mentioned here. Honestly, NONE of them suck and each has it's own personality. no matter which way you go, i'm sure you'll be happy.
I personally run the Trinity D3 and LRP SXX V2 Esc in my SC10. It drives great, lot's of power, in fact my truck can clear triples that most other trucks have to double.
Power is great in the motor, runs cool. ESC has tons of features and have never had a problem with it. The Error codes on the ESC are a great help as well. Uses lights instead of sound to change modes and values. Great in a loud pit or at the races.
Good Luck on your choice, but if you go with the D3 and LRP, you will be on happy Rc Racer.
Cheers!
Cheers!
