RC10B4/T4 Forum
#1459
Originally Posted by Zac R
hey
any one know where i can get (asc3971)t4/b4 stearing rack bearings besides from assocaited?
or the size of these bearings?
thanks
thanks
They are 1/8 x 1/4 bearings. The AE ones are $12 for 4. You can get them here for $1 each:
1/8 x 1/4 bearings
Plus you can get all the bearings you need there. The Revolutions are the BEST bearings I've ever used. The last forever, are very smooth, and best of all they are inexpensive.
#1460
+1 for avid bearings! awesome quality at a steal price
#1462
1/8 x 1/4 bearings
1/8 x 1/4 bearings
thanks
#1465
Anybody know the measurements of the shock o-rings in the B4. I'm going back to my paintball days to find some x-rings.
Thanks!!!
Sean
Thanks!!!
Sean
#1466
Trader Rating: 22 (100%+)
Originally Posted by AndyMoore
Thanks, I'll look into those as well!
You can get the Rayspeed ones from Yokomo direct at www.yokomousa.com
RS-27 RAYSPEED B4 Aluminum Rear Hub 0 Degree 34.80
RS-28 RAYSPEED B4 Aluminum Rear Hub 0.5 Degree 34.80
Go into shop and then hit find "b4" and it will get you to all the parts
#1468
Some of the set up sheets call for weight in the front and back. Where do you put these weights?
#1469
I just got a new T4 team kit. It comes with an 87T spur. What size pinion should I use with that spur to race with? Not a big track but does have some room for speed.
#1470
Probably a 18 or 19 tooth pinion will work fine for ya. Depends on the motor, but I think I ran a 19 with most everything.
The weights in the front can be glued right in under the front bulkhead. You'll see where you can tuck it in. That's where I put it anyhow. The rear you can put one in each rear triangle pocket of the chassis on either rear side of the battery. Or you can take apart the rear bulkhead shock towers whatnot and stuff it in front of the tranny and behind the bulkhead.
