Like Tree34Likes
RC10B4/T4 Forum
Old 11-29-2019, 05:09 PM
  #14416
rustyus's Avatar
Originally Posted by StahlVille View Post
Where can I find bodies for B4 with original 8mm shorter wheel base?
https://www.ebay.com/itm/Team-Associ...oAAOSwZ~pd2~hB
rustyus is offline
Old 11-29-2019, 05:25 PM
  #14417
ddd228's Avatar
Trader Rating: 24 (100%+)
ddd228 is offline
Old 11-29-2019, 06:40 PM
  #14418
ddd228's Avatar
Lightbulb
https://gshobby.com/content/associat...y-flamesred-b4
Better: https://gshobby.com/content/associat...b41-body-clear
ddd228 is offline
Old 11-29-2019, 06:49 PM
  #14419
ddd228's Avatar
https://gshobby.com/content/associat...per-pad-b4t4-2
B4T4 slipper pads! NA,
asc 9603
yeah,for 10 bucks.....
FOUND SOME.....
http://www.muddslidemotorsports.com/slpa9.html
T 4 chassis bargain!... https://www.ebay.com/itm/Associated-T4-FT-Chassis-carbon-ASC7441/273649936198?
$11.00
Last edited by ddd228; 11-29-2019 at 09:44 PM. Reason: asc 9603,asc 7441(regularly $45.00)
ddd228 is offline
Old 12-01-2019, 04:35 PM
  #14420
rustyus's Avatar
Go to Team Associated's site if you want some "4" series stiff stuff. Ha!
ddd228 likes this.
rustyus is offline
Old 12-01-2019, 05:56 PM
  #14421
ddd228's Avatar
Thumbs up CLEARANCE BLOW OUT.
YEP! 7441 5 bucks. Shock tower 75 cents....
7 bucks for shipping.
I bought a few items. Thanks Rusty
ddd228 is offline
Old 11-14-2020, 04:54 PM
  #14422
rustyus's Avatar
Broke down and went into the "inventory room", as the wife calls it, and dug out my new in package Interceptor T4 RTR body to go along with some Losi Step Pins/Pro-Line The Edge that I glued up.
ddd228, jbrow1 and AHR43 like this.
rustyus is offline
Old 11-14-2020, 04:58 PM
  #14423
rustyus's Avatar
Default Top Shaft
Klinik RC/Avid Associated B4/T4 Hard Coated Aluminum Top Shaft
Back by popular demand!
​​​​​​​Fits all B4, T4, B4.1, T4.1, B4.2, T4.2, Centro, SC10 etc
rustyus is offline
Old 11-14-2020, 05:29 PM
  #14424
ddd228's Avatar
https://i.imgur.com/XvieA7s.jpg
Go play in the mud.
Bigger tires for a track designed for 1/8 scale trucks.
Tire balancer.
https://i.imgur.com/VlSZV77.jpghttps://i.imgur.com/6r6Fxml.jpg
WhiteLX and rustyus like this.
ddd228 is offline
Old 11-15-2020, 09:52 AM
  #14425
Trader Rating: 28 (100%+)
Man that's a great looking truck! I have a brand new rtr body sitting around as well, pretty much enough brand new spare parts to rebuild a T4 to brand new as well. Someday I'll sit down and do it.
rustyus likes this.
jbrow1 is offline
Old 11-15-2020, 10:33 AM
  #14426
AHR43's Avatar
Guys. Here's the grass track 'Chihuahua Express' T4. New body by JConcepts. Paint by RC Bombshells. Have not had the tranny apart since buying the truck used off Ebay. Seems "o.k.". Diff adjusts o.k. Having a top shaft available in AL is a plus worth looking into. Probably break the tranny open for inspection and rebuild during summer 2021 break. Hardest part to find, though, was a set of pin-drive RR wheels. Thanks for the heads-up on the top shaft. Cheers. 'AC'
RC10T4 staged at grass track start/finish
rustyus likes this.
AHR43 is offline
Old 11-15-2020, 02:09 PM
  #14427
rustyus's Avatar
Thumbs up! That's my favorite modern semi-cab forward body style.
There is always that one part needed to keep these things running. The top shaft doesn't normally fail before the idler and diff gear, but it does wear down after time. Before I became aware of the Klink "limited run" top shaft, Associated "4" series diehards would have to cough up $$$ for the unicorn-isque part. Either that, or be very persistent/lucky in online dealings.
AHR43 likes this.
rustyus is offline
