Like Tree34Likes
RC10B4/T4 Forum
Old 10-29-2011, 11:08 AM
  #14191
AssocRacer's Avatar
The screws that hold the upper shock mounts are 4-40, so whatever size is needed for that.
AssocRacer is offline
Old 10-29-2011, 11:11 AM
  #14192
AssocRacer's Avatar
Originally Posted by Hokie_Racer View Post
Hey Guys,
I had an old T4 I bought in 03 and recently put in a 3800KV Castle brushless with a 2s lipo for racing. I had a 19 tooth pinion on it however it was too fast for the track, I bought a 16 tooth pinion however when I mesh it with the spur (I used the paper trick to get the mesh right) the spur is hard to move. I can rock the spur back and forth between the pinion teeth however when I turn the spur it feels like something is binding. Is this normal?? When I put the 19 tooth spur on the spur can spin really nicely. I don't understand what's going on any help would be appreciated.
Thanks again!
Had you recently done any tranny work? I had this happen once and it turned out the screws that hol the motor plate to the tranny were sticking out and hitting the slipper clutch plate.
Old 10-29-2011, 11:14 AM
  #14193
xBRxSAIGON's Avatar
Originally Posted by HighLife420 View Post
Well, picked up a used (but very very new) Factory team B4. I wanted to get back into buggies for a while, but didnt want to sink a ton of cash, so picked up the b4 instead of the b4.1.
Anyone have any recommendations on a setup for med/high traction smooth clay?
Front end
Shocks 27.5wt #2 piston 3 limiter 1 on the tower outside on the arm brown springs.
camber link 1/a/2 washers
30* caster somtimes on high bite I will go to 25* to mellow it out some going into turns.
Steering block in the middle.
2 washers for bump steer.
toe- 0
Ride Height 24mm
Rear end
Shocks 25wt #2 piston 2 limiters 4th hole on the tower inside on the arm green springs
camber link 1/b/ 1 washer with the u brace ground down and the new c hubs.
1* of anti squat
3* inboard toe sometime 3.5 inboard toe. More toe will lock the rear in a little more.
0* hubs Middle wheel base (blue washer infront)
Ride height 24 mm
If your track is smooth sometimes I put a black sway bar on the rear. It helps stable the rear out. Might be something to try if you want.
set the ball diff like the book says.
1/4 oz in each rear triangles. 3/4oz on reciever side.
all washers and limiters are .030
This a beast setup for the med. clay indoor.. let me know
xBRxSAIGON is offline
Old 10-29-2011, 11:18 AM
  #14194
HighLife420's Avatar
Trader Rating: 49 (100%+)
Thumbs up
Originally Posted by xBRxSAIGON View Post
Front end
toe- 0
Ride Height 24mm
Rear end
1* of anti squat
Ride height 24 mm
fantastic, thanks...will give that a try.
HighLife420 is offline
Old 11-15-2011, 10:22 AM
  #14195
Does anyone know what * hubs come with the older B4 ? Looking to try the setup above and have a set of K factory hubs that are suppose to copy the originals (3hole)
CRF311 is offline
Old 11-15-2011, 10:28 AM
  #14196
Tech Legend
Wild Cherry's Avatar
Will still need the Ae hub in order to achieve the lower camber link position the C hub offers....
Wild Cherry is offline
Old 11-15-2011, 12:03 PM
  #14197
Red face
I get it now... Thanks
CRF311 is offline
Old 11-16-2011, 11:37 AM
  #14198
IndyHobbies.com's Avatar
What FDR do most use for off-road clay tracks on their T4?
IndyHobbies.com is offline
Old 12-25-2011, 01:06 PM
  #14199
Default Reedy 3900kv associated xps-450 esc
Hey guys merry Xmas to all!!! Ok I got out with my fam today to test out my buggy but I got laughed back in the house with how slow it was running lolol!!! Ok I'm using a futaba 3pm radio with the above electrics & the car is def not reaching full speed....can anyone possibly tell me what to check to see what's causing the limited speed???
Thanks so much guys!!!!
Carmine!!!
Carmine is offline
Old 12-25-2011, 02:15 PM
  #14200
TeamWTF's Avatar
I'd try setting your throttle points on your ESC first (If you have not already done that)
If your using NiMh or NiCd packs they could be dead... Over time if left they will go bad
Make sure your throttle is at 100% on your radio when setting it up (Brakes also)
TeamWTF is offline
Old 12-25-2011, 04:59 PM
  #14201
rcfiend's Avatar
Trader Rating: 40 (100%+)
Hey is there a kick up adjustment on the B4.1, if so how do you make it?
rcfiend is offline
Old 12-25-2011, 07:47 PM
  #14202
Ok well that was the problem - throttle setting on radio was set to 0%...now new problem is I totally stripped my spur gear...I'm assuming this happened due to my lack of properly seating the motor onto the pinion gear....before I purchase a new spur gear, can anyone recommend the best spur gear for me to purchase? My motor setup once again is the Reedy 540R 3900kv brushless paired with an Associated XP SC-450BL brushless ESC. My pinion gear is a 48P-21T...
Thank you so much guys for all of your help!!!!
Carmine.
Carmine is offline
Old 12-26-2011, 03:12 PM
  #14203
Our local on-road track in Indianapolis is running stadium trucks for oval racing! So, I'm going to give it a try with my T4 tomorrow night. They have set the rules with 13.5 max brushless motors, foam tires and minimum 1/2" ground clearance.
I lowered mine for this first try using the zip tie method. If I like it and want to do more, then I will do the fuel tubing over the shock shaft inside the shock housing method.
Dropping the T4 down this low sure makes it look like a different truck! See pics. Mine is at exactly 1/2" with battery on board. Those are JACO 2.2" Eliminator foam tires. Perfect for the T4. Most are using Paragon traction compound they told me.
Attached Thumbnails RC10B4/T4 Forum-ovalt4setupscott-002r.jpg   RC10B4/T4 Forum-ovalt4setupscott-005r.jpg
Old 03-08-2012, 09:13 PM
  #14204
lemonader83's Avatar
Trader Rating: 16 (100%+)
Default Recommendations Please...
Peoples...
Need to make my B4 crazy fast and durable. What do you recommend?
So far thinking of doing...
-all aluminum/titanium parts
-Tekin Pro Motor/ESC Combo
-better Servo...recomendations?
-LiPO's...recommendations?
-bigger, stiffer suspension 90 mm?
-new body
-carbon chassis
Thoughts?
It's a team project b/c I really have next to no idea what I'm doing but LOVE THIS BUGGY!
Project RC10B4 Stealth Phase 1, please help!
lemonader83 is offline
Old 03-08-2012, 10:09 PM
  #14205
If you want a durable b4 then buy an rc8.2be instead. The B4 is anything but durable.
jimmer411 is offline
