Like Tree34Likes
RC10B4/T4 Forum
Old 09-05-2010, 11:23 AM
  #13561
Ae*Driver*70's Avatar
Talking AE Is Killer Of All......
8.5 in Buggy what is a good starting point for gearing !~
Ae*Driver*70 is offline
Old 09-05-2010, 01:55 PM
  #13562
Davidka's Avatar
Trader Rating: 85 (100%+)
Originally Posted by salvaticustomjs View Post
Alright guys I'm hoping i can get some help here... Ive tried every setting I could.. But my B4 still turns like a bus... My T4 has too much turning, I wish my B4 was the same... But I've tried shock settings, tires, weight balance and my steering EPA's on my radio are set perfectly. But, I'm just losing too much time in the corners because I have to slow down so much..I am on high traction clay/blue groove tracks with a lot of hairpin turns... here is my current setup
http://www.petitrc.com/setup/associa...tout201007.pdf
Any help is appreciated
Check your drag brake setting. If you have the right tires and a known good setup then you should not be having push problems with a B4.
Davidka is offline
Old 09-05-2010, 08:16 PM
  #13563
salvaticustomjs's Avatar
Trader Rating: 76 (100%+)
I figured it out Thanks Davidka... Setup was spot on but,it was my backup ESC and i never reset it
salvaticustomjs is offline
Old 09-05-2010, 08:22 PM
  #13564
Davidka's Avatar
I'd be embarassed to say how long I chased an oversteer condition on my stadium truck that was caused by the same setting.
Davidka is offline
Old 09-05-2010, 08:37 PM
  #13565
Lol tell us!! It cant be too bad! I love the new setup...gained .7 secs average
Old 09-06-2010, 01:13 AM
  #13566
are you running the b44 (.89) front shock shaft....?
SmItH_aLeX is offline
Old 09-06-2010, 08:47 AM
  #13567
No I'm not...never heard of that... Why is that done?
Old 09-06-2010, 11:45 AM
  #13568
Tech Legend
Wild Cherry's Avatar
You can just unscrew the ft shock eyelets 2 turns or buy the B-44 shaft , ends up the same droop...
Wild Cherry is offline
Old 09-06-2010, 12:41 PM
  #13569
The B44/B4.1 front shafts are .80, and if you run them you need to use about 2 .030 shock limiters to get the correct droop.
DanGriffin is offline
Old 09-06-2010, 02:26 PM
  #13570
Post AE Is Killer Of All......
isn't the new V2 shocks shafts change , Fronts are now .89 ?
Also good starting point on gearing AN 8.5 in 2wd buggy ? Anyone !
Old 09-06-2010, 03:25 PM
  #13571
wayboarder's Avatar
Trader Rating: 14 (100%+)
Its dependent on what speed control and motor your running, but a good starting point is 81/23, adjust from there while trying to maintain the same total number of teeth so steering really isn't effected.
wayboarder is offline
Old 09-06-2010, 03:55 PM
  #13572
i think it was three turns george...
Old 09-06-2010, 06:13 PM
  #13573
The front bodies are .89, and have been forever. The shafts changed from .71 to .80.
I run a 23t on my LRP 8.5
Old 09-07-2010, 02:43 AM
  #13574
ab1105's Avatar
Trader Rating: 20 (100%+)
Team Associated fans might be into this one....
R/C Evil Empire recently caught up with Team Associaed/J Concepts driver Tanner Denny.
At 15 years old, Tanner is one of the up and coming racers in the off-road circuit. Tanner took time out to talk to us about his racing, goals, practice, and more!
http://rcevilempire.com/2010/09/rcee...-tanner-denny/
ab1105 is offline
Old 09-07-2010, 05:27 AM
  #13575
mjk1210's Avatar
I've been running 23/78 on the buggy and 23/84 on the truck for a real long time and never had a heat issue with either on motors ranging from 10.5 to 6.5. Small tight tracks and large 120'+ straight tracks.
mjk1210 is offline
