Like Tree34Likes
RC10B4/T4 Forum
Old 08-18-2010, 04:48 PM
  #13471
Originally Posted by monkee View Post
whats on your rtr? those look similiar to the tread on mine
they're holeshots
Punisher72 is offline
Old 08-18-2010, 04:51 PM
  #13472
I'm really digging the Pro-Line M3 Calibers, they're hooking up really well at my local track. I tried a bunch of different tires, holeshots, goosebumps, inside jobs, bar codes, but so far it's the Calibers all the way.
Old 08-18-2010, 07:14 PM
  #13473
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
quick two questions.
1. Is it ok to grind the tabs off the anti squat shim?
2. To get a lipo to the back position what is required to do? I mean is there a new shock tower that is taller where the battery slides underneath?
mdwaeracer is offline
Old 08-18-2010, 07:41 PM
  #13474
monkee's Avatar
Trader Rating: 15 (100%+)
ok.. ive gone through 2 rear shock towers in less than a week.
is the carbon much stronger?
or are there aftermarket rear shock towers that are stronger?
monkee is offline
Old 08-18-2010, 07:57 PM
  #13475
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
There is a way to fix that problem..
Quad Racer 34 is offline
Old 08-18-2010, 08:10 PM
  #13476
monkee's Avatar
well staying off my lid is a personal goal.
until that is reached, however, is carbon stronger?
or are there aftermarket rpm or alum rear towers?
monkee is offline
Old 08-18-2010, 08:28 PM
  #13477
I've been racing my b4.1 for probably 2 or 3 months, i've been on my lid a number of times and I've never broken a shock tower. as far as aftermarket upgrades, i've searched for them for the b4 but had no luck finding any. i know they make alum. shock towers for the sc10, but I'm guessing the sc10 shock tower and the b4 tower are totally different?., I dunno....................................hold the presses, team integy makes an aluminum rear shock tower for the b4 for $29.99 in anodized silver or blue. I hope this helps Monkee http://www.integy.com/st_main.html?p_catid=70 here's the address
Old 08-18-2010, 08:33 PM
  #13478
monkee's Avatar
well im going to pop on my last spare tower tonite and i just ordered the only carbon tower that amain had in stock...
monkee is offline
Old 08-18-2010, 08:43 PM
  #13479
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Just be aware that the rear carbon shock towers do not have the new 4th shock position, you will have to add this.
Jmuck69 is offline
Old 08-18-2010, 09:24 PM
  #13480
monkee's Avatar
the 2 that i have broken and the 3rd im about to put on only have 3 holes?
monkee is offline
Old 08-18-2010, 09:45 PM
  #13481
VegasHB's Avatar
The 4th hole refers to drilling a new hole closer to center on the old style, with the new towers people still call it the 4th hole even though there's only 3. Associated basically eliminated the outer most hole on the new towers.
VegasHB is offline
Old 08-18-2010, 09:46 PM
  #13482
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 168 (100%+)
They all have only 3 holes...the 4th hole is drilled further inboard on the tower. The B4.1 and all the newer plastic towers come like this. The carbon tower is the old style that does not have this inner hole (although it still has 3). If you are using this inner hole than you will have to drill it on the carbon tower.
Matt Trimmings is offline
Old 08-18-2010, 09:53 PM
  #13483
i1justin's Avatar
Trader Rating: 20 (100%+)
and usually carbon snaps and breaks just as easy if not easier than the plastic parts. No flex in the carbon so if its stressed only one thing to do.... snap
i1justin is offline
Old 08-18-2010, 10:18 PM
  #13484
monkee's Avatar
most folks setups use a drilled hole closest to center of the vehicle?
i just got this buggy about a week ago.. i have been driving it with the shock on the outermost tip of the tower...
i wonder if that is leading to the easy breaking
monkee is offline
Old 08-18-2010, 10:34 PM
  #13485
Thomas P's Avatar
Thumbs up Ultralightweight Thin4
Just want to show my "new" car..regular FT B4, but with some mods, i hope it will be under 1000gr race ready.. the car is in progress, and i hope it will be done in a week or 2
Thomas P is offline
