RC10B4/T4 Forum
hey guys, i been so wrapped up in my 1/8th racing i havent been able to keep up with the 1/10 scale.
???? is the new T4.1 gear diff a direct fit to replace the old ball diffs?
I hope so but if not is it possible to order the complete new tranny and put it on an older T4.
THANKS!!
THANKS!!
What do you guy have your ride height set at on the B4's? I'm running Cav's CRCRC indoor setup with black rear springs and 25wt oil and seems like it bounces and bottoms out too much..
Run anywhere between 24 and 25 mm. Thats arms just a tad above level on the front and bones just above level in the rear. That setup from 09 is real finiky and should only be used in really similar conditions. Its not that great of a setup outdoors. If your outside and running in the heat u need to go up in oil a little, and ditch those blacks springs. Go up to greens.
THANKS!!
THANKS!!
Oh your running at the rc factory. You should try cavs b4.1 setup from portland. it is really good indoors and should be alot better for your track.
does jconcepts only sell their wheels in sets of 4?
and what tires are best for their wheels?
looking at the
http://www.amainhobbies.com/product_...Wheel-Yellow-4
looking at the
I just got a rtr b4.1, I want to change the servo to a JR 9100s but I cant find right servo arm... What does everyone use for these cars?
thanks
Hey guys, what do they mean when they say " motor cogs" or is "cogging" ?
I'm trying to get more steering. I have the ribbed front tires, is there something more aggressive?
