Like Tree34Likes
RC10B4/T4 Forum
Old 08-12-2010, 10:29 AM
  #13381
aeRayls's Avatar
Originally Posted by mxracer458 View Post
You have a link to that set up I run high bite smooth clau
Its on ae's site, you have to download the manual to see it. How high bite is your track? Which tires? Trackside is "slicks" type high bite.
aeRayls is offline
Old 08-12-2010, 10:36 AM
  #13382
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rcdude19641 View Post
Check out Ryan Cavalieri's setup from Trackside. I know it's old but this is the same setup I ran on my truck the last time I ran at OCRC and it was pretty good.
The plastic arms flex more which gives the car more traction. More traction = easier to drive and more driveable. The only time I don't run plastic arms is on the super high bite blue groove tracks.
What is the Lipo ballast (#7488) going to consist of?
Jmuck69 is offline
Old 08-12-2010, 10:39 AM
  #13383
#7488
B4.1 Rear Ballast Weight
• Fits: SC10 FT, B4.1 FT, T4.1 FT, SC10 2.4 GHz RTR
• 17g Zinc alloy cast weight for more rearward weight bias.
• Mates with #7487 arm mount for a completely captured fit with the chassis. Weight and mount retro-fit B4, T4, SC10 kits.
• Easy to install
Chris Jarosz is offline
Old 08-12-2010, 10:46 AM
  #13384
mxracer458's Avatar
Trader Rating: 47 (100%+)
Originally Posted by aeRayls View Post
Gold springs for that one. Its a really good setup for high bite. I think it worked better with the weight of nimh though, especially on high bite clay tracks like trackside. The new FT T4.1 setup is really good too. Been running it all year with a variations at diff. tracks.
Barcodes or suburbs good traction
mxracer458 is offline
Old 08-12-2010, 11:11 AM
  #13385
Jmuck69's Avatar
#7488
• Easy to install
Very nice! Any pics on the AE website soon?
Jmuck69 is offline
Old 08-12-2010, 11:39 AM
  #13386
aeRayls's Avatar
Give the 4.1 setup a try, its good. Except run 35wt oil in the front, try cutting a 1 coil off the blue front springs too. I like the truck with no weight added and the .5 hubs or 1* hubs. Ive been using losi 57 pistons in the front and 55's in the rear with 35wt all around and its great too.
aeRayls is offline
Old 08-12-2010, 10:15 PM
  #13387
monkee's Avatar
Trader Rating: 15 (100%+)
my front wheels are hitting the arms...
to the point where it will stop the wheel while turning.
guy at the track said that the b4 may have 2 different types of steering knuckles and there might be different ones depending upon the size tire/wheel you use..
is this true?
monkee is offline
Old 08-12-2010, 10:18 PM
  #13388
is this true?
You have the black spacer in the wrong spot... lol
Shirk is offline
Old 08-12-2010, 10:19 PM
  #13389
Tech Legend
Wild Cherry's Avatar
You got the caster on blocks back wards , (you have the left block on the right arm)
Wild Cherry is offline
Old 08-12-2010, 10:20 PM
  #13390
monkee's Avatar
lol shoot...
really thats it??
now i feel really stupid
monkee is offline
Old 08-12-2010, 10:34 PM
  #13391
I dont think he has the caster block on backwards....
Shirk is offline
Old 08-12-2010, 10:36 PM
  #13392
Tech Legend
sorry spacer fer sure, The block appears to be on correct arm.
Old 08-12-2010, 11:14 PM
  #13393
monkee's Avatar
yah that was it.
the turning radius is much more now
thanks
other question...
is there any other option for the front wheels other than the little shaft held on by an e-clip inside the steering knuckle?
something stronger than an e-clip?
or a way to alter the front into a larger shaft for different wheels?
monkee is offline
Old 08-12-2010, 11:38 PM
  #13394
Matt Trimmings's Avatar
Trader Rating: 168 (100%+)
yah that was it.
thanks
other question...
As for the front axles...lunsford sells some titanium ones that screw on (as well as AE now i believe). As for different wheels...you could always make something work but nothing is currently available and you would probably run into other issues.
Matt Trimmings is offline
Old 08-12-2010, 11:47 PM
  #13395
monkee's Avatar
is this it?
looks like it screws in from the back rather than e-clipping
http://www.amainhobbies.com/product_...-Front-Axles-2
monkee is offline
