Like Tree34Likes
RC10B4/T4 Forum
Old 08-11-2010, 06:42 PM
  #13366
mjk1210's Avatar
Originally Posted by monkee View Post
i received my b4 today in the mail. im going to use a sidewinder 5700 in it.
what pinion would you suggest i use?
maybe a 20 or 21 with the stock spur. Then check motor temps every couple minutes to make sure they don't start to spike over 150 or 160.
mjk1210 is offline
Old 08-11-2010, 06:45 PM
  #13367
mjk1210's Avatar
Originally Posted by dlbrown75 View Post
What size are the front and rear axles on the t4.1. 1/4 or 3/16''?
Has anyone ran black springs on the rear? I cant find any. Is it normal for the rear springs to touch the camber linkage? Please share any tips you have come up that only requires work not buying anything.. cya in the pits.
Check the spacer on the bushing on the top shock mount screw. Maybe turn it around. I know mine used to rub more with the lunsford titanium turnbuckles than the factory team turnbuckles as they are a bit bigger. For optimum performance it would be best not to rub at all.
mjk1210 is offline
Old 08-11-2010, 07:00 PM
  #13368
monkee's Avatar
Trader Rating: 15 (100%+)
well it looks like i only have an 18 and a 19 pinion..
how much speed difference will there be from a 19 to a 20 or 21?
monkee is offline
Old 08-11-2010, 08:01 PM
  #13369
monkee's Avatar
the used roller i bought came with no servo horn.
i tried to use one from an academy buggy but it sticks out from the servo to far.
the servo area is rather small.
am i missing something? or do i have to use an associated b4 specific servo horn
monkee is offline
Old 08-11-2010, 08:52 PM
  #13370
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
I'm having the same issue. hopefully someone can help us out.
Quad Racer 34 is offline
Old 08-11-2010, 09:36 PM
  #13371
You can only use an AE servo horn...
Shirk is offline
Old 08-11-2010, 09:42 PM
  #13372
monkee's Avatar
actually i figured it out...
i should have noticed tbh.
the braces that hold the servo to the chassis had a small shim in between the brace and the screws.
removed that and my academy svb2pro horn works perfectly.
its night and dark so i can only drive this up and down my driveway but i cant wait to try this thing out on a track! seems very zippy!
monkee is offline
Old 08-12-2010, 03:14 AM
  #13373
mjk1210's Avatar
The speed difference probably won't be an issue unless on a very large track. The motor temp would usually be more a concern. Just keep an eye on it. Brushless isn't like brushed. They work in a range of gear ratios but too high can be as bad as too low for temps
mjk1210 is offline
Old 08-12-2010, 04:30 AM
  #13374
mxracer458's Avatar
Trader Rating: 47 (100%+)
On cabs. T4 trackside setup you running gold or silver springs ip front
mxracer458 is offline
Old 08-12-2010, 04:38 AM
  #13375
The stock spur should be 81t, so a 19t pinion should be fine.
Dnyd is offline
Old 08-12-2010, 06:51 AM
  #13376
Liv2race's Avatar
Trader Rating: 32 (100%+)
my lil bro runs his mamba max 5700 at 18/19 pinion--84/87 spur........but of course it depends on exactly what you are doin and where your doin it....as stated before check dat temp !!
Liv2race is offline
Old 08-12-2010, 09:51 AM
  #13377
aeRayls's Avatar
Gold springs for that one. Its a really good setup for high bite. I think it worked better with the weight of nimh though, especially on high bite clay tracks like trackside. The new FT T4.1 setup is really good too. Been running it all year with a variations at diff. tracks.
aeRayls is offline
Old 08-12-2010, 10:06 AM
  #13378
WIITA's Avatar
Trader Rating: 43 (100%+)
Question for you associated guys, I picked up a new b4.1 and on the rear shocks the green rear spring rubs against the shock body no matter how I trun the spring on the collars. I usually wouldn't mind but it does rub pretty hard on the body and can tell a difference in the two shocks. Anyone have a fix for this problem? Thanks.
WIITA is offline
Old 08-12-2010, 10:16 AM
  #13379
mxracer458's Avatar
You have a link to that set up I run high bite smooth clau
Old 08-12-2010, 10:25 AM
  #13380
aeRayls's Avatar
Yeah both of my rear springs rubbed real bad out of the new kit. Take some sandpaper and sand the high side off the bottom of the spring. Do one side at a time. The color coating was real think on mine.
aeRayls is offline
