Like Tree34Likes
RC10B4/T4 Forum
Old 07-26-2010, 08:47 AM
  #13171
Tech Legend
Wild Cherry's Avatar
Originally Posted by Jmuck69 View Post
I have read that the CVA* helps square the car up out of corners and the CVD* helps keep the suspension active and doesn't lock it. Is this true, and if so this could be another tuning aid.
You got it, but the opposite or the other way around of what you said...
Wild Cherry is offline
Old 07-26-2010, 09:35 AM
  #13172
Davidka's Avatar
Trader Rating: 85 (100%+)
Are the CVA's a different joint? Anyone have a link to a photo?
Davidka is offline
Old 07-26-2010, 09:37 AM
  #13173
Tech Legend
Yes , CVA is way different Dave ...
CVD Barrel for pivot on axle
CDA Barrel for pivot on the dog bone
CVA Binds more than CVD
Picture of a CVA bone
Attached Thumbnails RC10B4/T4 Forum-cva.png
Old 07-26-2010, 09:41 AM
  #13174
yup, shocks are fresh and im running on indoor clay here in sothern CA (westcoast, ocrc, lrh). thanks for the tips... i'll try those out first
Originally Posted by Eli View Post
maybe go up 2.5w on rear shock oil. but may have to much adverse affects. you may want to add weight to the lipo if youre running lipo before you go getting all frustrated. im running a strip of thin lead down middle approx. 70 grams and then i have 14 grams (2 7gram thin pieces of lead) on front and back of battery. Using check point 3800 so it fits exactly in the middle of battery compartment.
My car is pretty planted on the track
R u running indoor clay track?
oh yeah, make sure youre ride height is set correctly 24mm from bottom of trans and 24mm right behind bumper. and your shocks are fresh right?
justxroro is offline
Old 07-26-2010, 09:58 AM
  #13175
Davidka's Avatar
^^That will make no difference. The configuration and materials (I assume) of the pivot are the same so the amount of the bind has to be the same as well. If the dogbone is aluminum (softer) then that would have an effect.
An upside I can see is that someone could make a boot for the CVA allowing it to cleanly retain lube. That would make a meaningful difference.
Davidka is offline
Old 07-26-2010, 10:02 AM
  #13176
Tech Legend
Dave ,
Where the pivot is located makes a huge difference...
Old 07-26-2010, 10:53 AM
  #13177
Davidka's Avatar
Dave ,
I don't believe that. Besides, the pivot isn't in a different place, it's connection is just reversed.
Why do you think it makes a difference?
Davidka is offline
Old 07-26-2010, 11:25 AM
  #13178
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Tamiya did that on the Frog.
Cameron Kellogg is offline
Old 07-26-2010, 11:27 AM
  #13179
Tech Legend
The way the joint spins on the car while the arm is moving up & down & the gyroscopic forces ...
Old 07-26-2010, 11:56 AM
  #13180
Davidka's Avatar
Unless the joint spins on a different axis (further inboard from the wheel for instance) then all of these forces would be the same.
Davidka is offline
Old 07-26-2010, 12:02 PM
  #13181
Tech Legend
Not the same Dave , sorry ...
A Clue
when you rotate a bent CVD gyro forces makes the joint straighten or flat ....
Old 07-26-2010, 01:35 PM
  #13182
Davidka's Avatar
A Clue
That happens to all universal joints, it's caused by friction, not gyroscopic forces (did you make that up? ). Given the barrell and pins are presumably the same size and same material, placed in the same location, the friction would be the same.
Does anyone actually know if there's a difference?
Davidka is offline
Old 07-26-2010, 01:40 PM
  #13183
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Jmuck69 is offline
Old 07-26-2010, 02:11 PM
  #13184
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hey guys,
a 1mm shim gives 2 deg anti-squat? I have a 4.1 and want to know which rear toe config set up should I run, the 2deg or 3deg? The 2 deg should provide a "looser" feeling and better rotation, right?
yyhayyim is offline
Old 07-26-2010, 03:02 PM
  #13185
The CVA has no handling difference from a CVD. The reason the CVA was used is because MIP has trademarked the CVD. The reason Ryan's setups show CVDs is because at the time that they were made we didn't have CVAs to run yet.
The 2* of rear toe will make the car looser and rotate more than the 3* of toe.
Chris Jarosz is offline
