Like Tree34Likes
RC10B4/T4 Forum
Old 07-05-2010, 12:23 PM
  #12991
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Proline has it for sale on their website now.
Jmuck69 is offline
Old 07-06-2010, 06:54 AM
  #12992
mandy116's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Wild Cherry View Post
1/2 oz by the receiver to help off-set the weight of the ESC
1/4 oz on each side in back of battery tray on chassis
1/2 <> 1 oz behind bulk head in ft of transmission
When i weighted the 3pk rx vs my LRP spx with the wires there was a difference of 1.5oz? And where should i run my ackerman with the portland setup? Also to make the rear rotate a little more off-power should i take off the .5 hubs and go back to stock? lmk thanks cherry
mandy116 is offline
Old 07-06-2010, 10:22 AM
  #12993
Tech Legend
Wild Cherry's Avatar
Mandy
Use the back holes on the Ackermann...
Yes , if you replace the .5 hubs with the standard hub your rotation will be faster ..
You could also add anti-squat with the .5 and this will also increase rotation in the turns...
I personally only use 1/2oz to off-set the ESC weight , you can use more or less if needed ....
Wild Cherry is offline
Old 07-06-2010, 08:03 PM
  #12994
Default pinion probs
Just got my t4 running. novak 3s brushless system. Any way tried test runs and my pinion gear will not stay on. Will run for a minute then pinion will loosen up and come off. Also my spur gear has a little damage. What am I doing wrong?
dlbrown75 is offline
Old 07-06-2010, 08:25 PM
  #12995
Locktite the pinion grub screw!
CODMAN is offline
Old 07-07-2010, 12:11 AM
  #12996
Armaan's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Jmuck69 View Post
With steel inline front axles!
http://aedownloads.com/press/in_070610_b4.1-ft.pdf
Armaan is offline
Old 07-07-2010, 01:00 AM
  #12997
Tech Legend
Default Team Lunch Table, where the kool guys sit ....
G wiz ?
While you guyz are still waiting for the mail order man or discount codes ?
I already got and built my new Team Sc-10 I purchased from my local race facility...
Ha !
BDW
The skuffy look is from grinding tires....
Attached Thumbnails RC10B4/T4 Forum-team-edition-ae-sc-10-buy-local.jpg
Old 07-07-2010, 01:07 AM
  #12998
JCathey's Avatar
Cherry
I am putting my b4 together and need a good starting setup. Thanks!
JCathey is offline
Old 07-07-2010, 01:18 AM
  #12999
Tech Legend
Joe
Sent you a Pm
Old 07-07-2010, 01:43 AM
  #13000
i think everyone had black tire chunck on their face tonight from making slicks LOL!
G wiz ?
Ha !
BDW
SmItH_aLeX is offline
Old 07-07-2010, 01:44 AM
  #13001
hey jc, what setup did wild man send ya?
Old 07-07-2010, 02:01 AM
  #13002
thats the new fashion style.
Shirk is offline
Old 07-07-2010, 03:08 AM
  #13003
JCathey's Avatar
Alright I see a couple of pages back there are some different towers? What's different? More lay down holes it looks like for the rear but the front what's up?
JCathey is offline
Old 07-07-2010, 06:18 AM
  #13004
kyle3333's Avatar
The rear also provides more clearance for taller battery packs. The front tower has more material where the ball studs are screwed in.
kyle3333 is offline
Old 07-07-2010, 08:29 AM
  #13005
Default Set-up trouble
Can someone please tell me where I can find different setups to try. All I can find is blank setup sheets. Or you could just share your favorite setup with me and ill try it. Thanks
