Like Tree34Likes
RC10B4/T4 Forum
Old 05-23-2006, 07:13 PM
  #1216
Lost Aggresiva's Avatar
Originally Posted by Manning
Anybody run the Novak GTB 7.5 Velociti combo in a T4?
Just wondering if it will be enough...I'm currently running pretty mellow 14 and 15 turn brushed motors and want just a little more power than what they provide. Don't want crazy amounts of power because the tracks I race at are outdoors, usually very dry, and rough and rutted from all the nitro cars crashing, so there's not an abundance of traction....
I've been wondering that myself. The 6.5 sounds good, but would the 7.5 be a bit easier to hold on to on the loose stuff. Anyone tried one yet?
Lost Aggresiva is offline
Old 05-23-2006, 11:39 PM
  #1217
Racing4Evo's Avatar
Originally Posted by jbrow1
Best way to fill em is get em almost to the top. Then place the piston about 1/4" from the top. Fill a little more until it just convexes over the top. Put on top. Check shock to make sure it moves to top fully with no change in resistance. Just keep bleeding until there is no change in resistance from bottom to top. Putting the piston to 1/4 from the top keeps you from wasting so much oil. After awhile you get pretty good and can hit it first shot.
I personally drill 1/16" hole in the top at an angle like the yok caps. Then find a small phillips screw and screw in the hole. You've just made your own trouble free easy to bleed, bleeder tops. I find the screws in a package in the shelf building section at the hardware. Smallest ones you can find. Won't work with aluminum tops.
Thanks.
Racing4Evo is offline
Old 05-23-2006, 11:52 PM
  #1218
nutfluff's Avatar
I tried a 7.5 in my 4WD but it wasn't enough so I bought a 6.5 and it's perfect. They are SUPER SMOOTH and FAST. Should be enough to get you going in mod for a long time. Mine is two race days old an would be willing to let it go reasonably cheap!!! PM me!!!!
nutfluff is offline
Old 05-24-2006, 11:03 AM
  #1219
Sp1ke's Avatar
why'd you wanna sell it if it was so good?
Sp1ke is offline
Old 05-24-2006, 11:18 AM
  #1220
killer89's Avatar
Trader Rating: 41 (100%+)
He said that the 7.5 wasn't enough for 4wd... 4wds need like 9-11T depending on the track to get going...
killer89 is offline
Old 05-24-2006, 04:33 PM
  #1221
jamescam's Avatar
For anyone interested I am taking some time off racing and have the truck mentioned below up for sale http://www.rctech.net/forum/showthread.php?t=114820
Originally Posted by jamescam
Well it took longer than I would have liked and cost more than my wife could have ever imagined but my Dream Stock Racing T4 is finally complete! For those who don't know what I'm talking about go back a few pages and you will find the history.
Attached are pictures of the completed truck, and below are the parts that made the final cut along with my personal price/performance rating:
- Robinson Racing Super Lite Aluminum Pinion - B+
- Team Associated Composite/Plastic Chasis - A
- Team Associated Factory Team Battery Strap Thumbscrews - A+
- Yokomo Bleedable Shock Caps - A+
- Lunsford Titanium Quick Tune Shock Mounts - B-
- Lunsford Titanium Screw Kit - D (price is not worth benefit & no matter how careful you are you will strip at least 1)
- Lunsford Titanium Turnbuckles - B
- Lunsford Titanium Hinge Pins - B
- Lunsford Titanium Front Axles - B+
- Trinity Light Weight Slipper Plates - C- (No weight savings, but they look cool)
- RPM Black Gear Cover - B+
- Acer Racing Ceramic Nitro Pro Series Diff Balls - A+ (smoothest diff I ever built)
- Acer Racing Ceramic Nitro Pro Series Thrust Balls - B-
- Acer Racing Ceramic Nitro Pro Series Ball Bearing Set - D+ (a lot of key bearings not in kit)
- Team Losi Titanium Ball Studs & Ball Cups - B- (great but expensive for ball studs, hex screw is nice!)
- Racer's Edge 0 Degree Hard Anodized Rear Hub Carriers - A-
I will probably add the MIP Shiny CVD's eventually and I am still unsure where to mount the personal transponder. Now onto my next project!
jamescam is offline
Old 05-25-2006, 09:21 AM
  #1222
Sp1ke's Avatar
oh ok... my bad... anyone has any gearing tips regarding a novak 5800 setup? i'm using 20T/81T in stead of the recommended 22T/81T... feels good... but will this hurt the esc? was mildly warm after about a 3-5 mins of play...
Sp1ke is offline
Old 05-25-2006, 10:57 AM
  #1223
nutfluff's Avatar
Reading is FUNdamental!
nutfluff is offline
Old 05-28-2006, 02:43 PM
  #1224
AaronR's Avatar
Trader Rating: 113 (100%+)
I just picked up a set of Lunsford Ti turnbuckles (p/n 2005). What would be a good set of ball caps/ends and do I need to replace the ball studs?
AaronR is offline
Old 05-28-2006, 11:17 PM
  #1225
I am using, and have an extra set of, rpm end caps, work great.
HTH
Rod
gatermaxx is offline
Old 05-29-2006, 01:19 AM
  #1226
Default Brushless system in a FT B4 for mod class???
I was just wondering if anyone is running brushless in a B4 for mod classes, and if so what are you running?
Cheers!
mztaim is offline
Old 05-29-2006, 02:52 AM
  #1227
B4Bandit's Avatar
I run a novak 5.5 and it is awesome. I'm thinking of going to a 6.5 because the 5.5 is a little fast for me and the track that I race on. Never had a problem and I actually run two heats in one battery sometimes!!! (3600's)
B4Bandit is offline
Old 05-29-2006, 02:53 AM
  #1228
Hollowman's Avatar
I run my B4 with 5,5r GTB with the transmitter turned back on the POWER !! because a 5,5r in a B4 is insane for the track that i run on .
Yeah same with me i run 2 heats with my 4200 and then i need to run it empty on the parking lot
Hollowman is offline
Old 05-29-2006, 03:12 AM
  #1229
mangemutt's Avatar
Talking b4
i mite go brushless.has anyone tried the reedy brushless system yet?
mangemutt is offline
Old 05-29-2006, 12:36 PM
  #1230
Sp1ke's Avatar
I'm using a 5800SS motor...the speed was just nice at sportsman setting... my 3300 pack lasted about 20 mins... awesome stuff...
Sp1ke is offline
