RC10B4/T4 Forum
#1201
Originally Posted by jbrow1
Check out the B4 forums. Charlie Perez thread in the B4 setup section. Somewhere between pages 70 and 80 he has a picture of how his fan is mounted. Not on the top of the speedo, but glued to the chassis standing up in front of the speedo.
#1203
Anybody run the Novak GTB 7.5 Velociti combo in a T4?
Just wondering if it will be enough...I'm currently running pretty mellow 14 and 15 turn brushed motors and want just a little more power than what they provide. Don't want crazy amounts of power because the tracks I race at are outdoors, usually very dry, and rough and rutted from all the nitro cars crashing, so there's not an abundance of traction....
#1204
Sp1ke- I've got a picture but you cant see the other side of the body with the hole in it, lol. This picture will give you an idea of where it is.
http://i4.photobucket.com/albums/y12...41holespot.jpg
#1205
hahah i can barely make it out wheelnut... besides, i have already mounted my esc with the fan on the battery brace itself...hahah now need weights to even up my weight bias...
#1206
if you get the Illuzion body for the B4 with scoops it will have enough room for your fan and you can cut out the scoops for venting.
#1207
Works great !
The airduct & extra space helps keep the ESC cooler...
#1208
Alright guys. I am a 1/8 buggy racer, but my local track is talking about building a indoor offroad for the winter. What is the best 2wd electric buggy? I know of course the B4 and what does losi have and how do they compare? Also is there a new version of the B4 coming out?
#1209
wait for the XXX-CR to come out and then decide on which one... Apparently, the CR fixes the steering problem with the bk2s, and if this is true, it might just dominate...
#1210
the losi team ran the cr at the worlds and still had problems but they won the nats with it
#1211
#1212
How do you guys build your shocks. I'm having a hard time getting the shock to have the correct rebound and not have air in it. Going by the book leaves way too much oil in the shock.
#1213
There will normaly be some air left in the shocks. It's just assumed that the air will settle at the top and allow the shock to perform properly.
#1214
Does anyone know why AE has chosen to stay with this design for so long? What are the benefits to this versus the bladder shocks which seem to be a lot easier to build and build consistently.
#1215
I personally drill 1/16" hole in the top at an angle like the yok caps. Then find a small phillips screw and screw in the hole. You've just made your own trouble free easy to bleed, bleeder tops. I find the screws in a package in the shelf building section at the hardware. Smallest ones you can find. Won't work with aluminum tops.
