Like Tree34Likes
RC10B4/T4 Forum
Old 03-19-2010, 05:50 PM
  #11986
Armaan's Avatar
Trader Rating: 49 (100%+)
Originally Posted by not home View Post
the ft axles are very well known to break, i have broken a few. the x factory steel ones are excellent. no play, and will not break. they have a button head screw on both sides for no play. titanium axles wont help much more.
Cool, I'll nix the Lunsford axles in favor of the X Factory ones. Where did you buy yours from?
Thanks in advance.
Armaan is offline
Old 03-19-2010, 06:40 PM
  #11987
rripp's Avatar
Originally Posted by Armaan View Post
I keep snapping off the AE blue factory team aluminum axles. Has anyone had any luck with the X-Factory steel axles or the Lunsford Titanium axles?
AE has titanium axles coming out but it may be a couple months before we see them.
rripp is offline
Old 03-19-2010, 06:42 PM
  #11988
Armaan's Avatar
They're going to be identical to the Lunsford units. I **think** the shear strength of steel is higher than Titanium, but I'm sure the grades of the metal will dictate to where or not that presumption holds true.
Armaan is offline
Old 03-19-2010, 07:53 PM
  #11989
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
What would a aluminium front bulkhead in a B4 do to the handling of the car?
RC10B4_Mafco is offline
Old 03-20-2010, 12:58 AM
  #11990
Armaan's Avatar
Add some weight to the front...pretty sure that's about it.
Armaan is offline
Old 03-20-2010, 01:30 AM
  #11991
Tech Legend
Wild Cherry's Avatar
Thanks in advance.
Your lost , the Lunsford is the best part ,steel bends the Ti don't...
Wild Cherry is offline
Old 03-20-2010, 01:32 AM
  #11992
Tech Legend
adds on-power steering
less high speed
less infield steering
Old 03-20-2010, 01:54 AM
  #11993
I felt that I had heaps less off power steering. How could I gain some off power steering for a grass track?
Old 03-20-2010, 07:41 AM
  #11994
Davidka's Avatar
Trader Rating: 85 (100%+)
Depends on the quality of steel. Any decent chromoly steel is stronger than the best Ti alloys. I have never seen a stock steel axle damaged aside from the threads. The only real benefit of Ti for that application is light weight. The only reason Ti ball studs are stronger is because the steel used in them is junk.
Davidka is offline
Old 03-20-2010, 12:09 PM
  #11995
Tech Legend
I'v personally bent more than a few steel axles Had the Lunsford for about year now , not one issues with the part...The strongest by far...
Mafco
softer ft spring
add weight on back of car
move battery back
tighter slipper
tires
Old 03-20-2010, 02:45 PM
  #11996
euromut's Avatar
Newb question. Speaking of titanium. What thread pitch are the FT Turnbuckles? 4-40? Just curious before I get RPM ends.
And when the hell are the new 4.1 brushlesses gonna start shipping?
euromut is offline
Old 03-20-2010, 08:15 PM
  #11997
Mafco
softer ft spring
move battery back
tighter slipper
tires
cheers cherry
Old 03-20-2010, 09:46 PM
  #11998
Trader Rating: 23 (100%+)
when i put mine on, it felt much more stable, and more calm on the track. i really liked it.
not home is offline
Old 03-20-2010, 09:49 PM
  #11999
Whats the weight difference between the stock and alum ones??? and are aluminum parts a good way to add weight to your car or are stick on weights better for placement??
Neccros is offline
Old 03-20-2010, 10:18 PM
  #12000
I got a set of Al caster blocks from a really cool guy at the track and was thinking of replacing my plastic ones with them. I've broken 2 caster blocks in 6 trips to the track.
Other than more broken arms, are there any other issues that might pop up?
Am I better off with the plastic ones?
lusifur is offline
