Like Tree34Likes
RC10B4/T4 Forum
Old 03-18-2010, 07:08 PM
  #11956
Trader Rating: 23 (100%+)
eh, no need for the tekins in my opinion. just crank the timing on your lrp, gear it correctly, and drive it right.
not home is offline
Old 03-18-2010, 07:41 PM
  #11957
tekins are way better for using the boost way more adjustable and cheaper and you dont have to worry about it randomly catching on fire like lrp speed controls do! lol
92Z28 is offline
Old 03-18-2010, 07:47 PM
  #11958
ha, yeah because a lrp sxx costs may more than a rs pro. and yup, we all know how often you see an lrp blow up, or,"catch fire!"
novak on the other hand, maybe.
tekins are more adjustable but who says they are faster? what big pros are using them? they are more of a dominant speedo to spec classes, where a speed passion, or an lrp can keep up to.
not home is offline
Old 03-18-2010, 08:10 PM
  #11959
zanernator's Avatar
what starting spur/pinion setup
novak gtb
novak 10.5ss
venom 5000 25c burst 20c consistant
zanernator is offline
Old 03-18-2010, 08:44 PM
  #11960
novak gtb
novak 10.5ss
78/26 ish
not home is offline
Old 03-18-2010, 09:54 PM
  #11961
Davidka's Avatar
Trader Rating: 85 (100%+)
Rhetorical question? Pros don't run stock/spec classes.
We're lucky at Trackside, we have a strong modified turnout so speed controls have little to nothing to do with competitiveness. It'll start chaffing the SCT guys soon enough.
Davidka is offline
Old 03-18-2010, 10:03 PM
  #11962
Krio's Avatar
Trader Rating: 159 (99%+)
+1
The better question is what pros don't run it in spec carpet classes.
I have a feeling I'm going to be tech'd a lot this summer with my sc10 and RSpro.
Krio is offline
Old 03-18-2010, 10:04 PM
  #11963
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Next topic
Tony Newland is offline
Old 03-19-2010, 05:39 AM
  #11964
what im saying is, i dont think a tekin rs pro vs a sxx stock spec or sxx will be much of a difference. just crank the timing up on the sxx and gear it right and you have yourself something to compete with a tekin. i think tekins are very overrated.
not home is offline
Old 03-19-2010, 11:00 AM
  #11965
yourstruly22's Avatar
Can some on tell me what affects a up axle height has over a down one, and black ball studs on the the steering rack both holes?
yourstruly22 is offline
Old 03-19-2010, 11:30 AM
  #11966
squarehead's Avatar
Trader Rating: 75 (100%+)
Default Diff weights
I saw some discussion earlier, but never saw a definitive answer here, so here it is.
Concerning the fallacy that a ball diff is lighter and a gear diff is heavy and bulky, consider this--both Associated trannies, without motor plates and slipper assemblies weigh exactly 74 grams.
Head to head, weight is identical and not a distinguishing factor in racing use.
squarehead is offline
Old 03-19-2010, 12:02 PM
  #11967
Tech Legend
Wild Cherry's Avatar
[QUOTE=92Z28;7155853]tekins are way better for using the boost way more adjustable and cheaper and you dont have to worry about it randomly catching on fire like lrp speed controls do! lol[/QUOT
I'v seen more Tekins toast then any other brand over the last 6 months...
Good luck ....
Wild Cherry is offline
Old 03-19-2010, 12:13 PM
  #11968
Krio's Avatar
[QUOTE=Wild Cherry;7158526]
Good luck ....
And I've seen more lerps toast than any other brand over the past six months. Ya win some ya lose some.
Krio is offline
Old 03-19-2010, 12:16 PM
  #11969
Tech Legend
moving the axle up = more camber gain , less but smoother steering
moving the axle down = less camber gain , more steering and more responsive steering
black ball is shorter than standard standard stud, removes bump steer when mounted on Ackerman
mounting ball stud forward on Ackerman = less steering
moving stud back = more steering...
Old 03-19-2010, 12:18 PM
  #11970
Tech Legend
[QUOTE=Krio;7158560]
Lrp wins almost everytime where I race...
beat that
