Like Tree34Likes
RC10B4/T4 Forum
Old 03-11-2010, 09:26 AM
  #11851
Tech Legend
Wild Cherry's Avatar
Default .060 offset transmission
I use the standard shaft no mods...
you do have to use longer tranny screws
should fit otherwise.....
Wild Cherry is offline
Old 03-11-2010, 09:52 AM
  #11852
Bremelo's Avatar
Originally Posted by Double Dee View Post
Ya geo we know now. What did you think about that run tuesday. Q 3rd I wish I could get more runs like that. I had a big smill all day and love this new set up. it was the best my car had been in a long time. All top 3 AE ran that set up but with green front and gold rear. springs
Nice run the other night Darin! All this new set up change stuff is making my head spin.
sent you a pm.
Bremelo is offline
Old 03-11-2010, 10:26 AM
  #11853
Bobby Z's Avatar
I was confused for a bit there. For some reason I was thinking the 0.060" spacer was bigger than it actually is. I did the same mod with the same size spacers and with longer transmission screws.
I tried to move it more than 0.060" and this is when I ran into issues with outside slipper plate not engaging the top shaft properly.
Bobby Z is offline
Old 03-11-2010, 10:33 AM
  #11854
Davidka's Avatar
Trader Rating: 85 (100%+)
Spacing over the motor seems a little overkill since the left side of the car is heavier no matter what (speed control) why not just compensate with weight to balance both the speedo and motor on the right side of the chassis?
Davidka is offline
Old 03-11-2010, 10:38 AM
  #11855
Tech Legend
I doubt moving the plate is anything big , but a little here and a little there adds up ....
Old 03-11-2010, 10:46 AM
  #11856
What you are really after is to center the rotor. There is so much torque being applied via the rotor that putting it in the center line of the car very well could make the car more consistent.
DanGriffin is offline
Old 03-11-2010, 10:48 AM
  #11857
aeRayls's Avatar
I ran the motor plate spaced about 2mm last year and wasnt all that impressed. I dont think its that big of a difference it needs to be more. When I saw BT's car at CRCRC it was spaced 4mm. Which you cant do without a different topshaft.
I am bummed however, I placed an order with ae for the new towers and they said the front was out of stock but might be in before my order processed. Well I got the new rear towers but the front towers were all the old style.
aeRayls is offline
Old 03-11-2010, 10:51 AM
  #11858
aeRayls's Avatar
So Dan, just checked your sig. Didnt know you switched, so did I. Me Jacob and Chris are heading to crcrc this weekend you goin?
aeRayls is offline
Old 03-11-2010, 11:03 AM
  #11859
???E-Racer's Avatar
Rayls you ever been to the cactus classic.
I dont think I will ever get that far in rc racing, but I know Paul Sinclair
is definitly going.
???E-Racer is offline
Old 03-11-2010, 11:07 AM
  #11860
aeRayls's Avatar
No I havent been to the CC yet. My job requires too much of my time. Races like that require a whole week off.
aeRayls is offline
Old 03-11-2010, 11:37 AM
  #11861
Davidka's Avatar
I suppose it would mean less weight to add to achieve balance.
I can buy that, it would be easy enough to figure out where the rotor's center of mass is.
Davidka is offline
Old 03-11-2010, 12:03 PM
  #11862
AssocRacer's Avatar
Milled plate=more surface area=better cooling. Also, as stated before, the milled plate won't flex like the flat plate will. Hence why 1/8th scale shock towers are always milled out in the areas where it doesn't bolt to something. That's not a weight savings thing, that's to keep the shock towers from flexing too much. AE's main reason for making the milled motor plate was for heat dispersion when people where using really hot modified brushed motors. Heat isn't as much of an issue now with brushless motors. And i personally believe that the weight difference between the two is really not noticable.
AssocRacer is offline
Old 03-11-2010, 01:17 PM
  #11863
astroboy403's Avatar
what would be a good degree for stock buggy in the racers edge rear hubs. just wanting to know if i should get the half or the hole degree hubs. thanks
astroboy403 is offline
Old 03-11-2010, 02:45 PM
  #11864
I really doubt it is a flex thing with the motor plate. Metal doesn't necessarily bend more if you machine more (especially partial lateral slots). I am not saying people are right or wrong, but my inclination without putting the two parts in a stress analyzer would be that they flex equally.
Old 03-11-2010, 02:49 PM
  #11865
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Maybe this is an indication of what they are developing for the B5. They are going back to the aluminum tub.
Jmuck69 is offline
