RC10B4/T4 Forum
I just got my T4 together last week and ran wed night and TQ'd/won.
56F 35 Losi oil 3 limiters
middle on tower, outside on arm
link - inside on tower no washers inside on caster block
30' caster blocks
middle spindle height
1 bumpsteer washer
rear ackerman on steering plate
55R 30 Losi oil 2 limiters
middle on tower inside on arm
hubs back
std hubs
link - inside on bulkhead 1 washer
middle on hub
ride height 31mm f 30mm r
Trinity 5000 40c battery centered (have to cut one foam in half)
Tekin 13.5 geared 22/78
fastest lap 16.5
fastest mod buggy lap 16.2
Pink tapers F&R, trinity foam, zip grip just the rears
Losi pistons are alot more consistent on our track, both my B4 and T4 jump tons better and are faster back to back
30' caster blocks
1 bumpsteer washer
hubs back
std hubs
middle on hub
fastest lap 16.5
I was running 30 wt front and 35 wt rear so what oil would I run with 56 pistons instead of the #2 AE piston.
I'm racing on carpet track with jumps indoors so there are no bumps and slowing down the body roll may actually be a good thing on the high bite surface. My car was cornering very well last night but it was a bit nervous in some sections where the car has to jump, land and then jump again.
Long links and laying the shocks down will make it easier to drive on high bite surfaces
Stop stressing over the o-ring..
It’s a $4 part. I read an article years ago where Cliff Lett said we should change them after ever race meeting.
I change them about once a month (just the o-rings) for a consistent feel/slide of the shock shaft.
Every shock is going to leak some oil. It’s called pressure. When you have a cylinder full of oil (no air) then push a shaft in, oil will leak out at the weakest point until the pressure equalizes (bleeding a shock). But when a shock is working on the car there are still pressures working inside the shock body. Visualize this, push the shock shaft up into the shock body, and now pull it out quickly. The oil is meant to travel throw the piston holes, if it can’t do that fast enough then a bit of it will be pushed out past the o-rings (the next weakest point). Which you may describe a leaking, I may describe as normal.
As we don’t know each other on the forum personally it is hard to know how we each preparing and maintain a car or fill shocks.
I have raced off road electric from ’86-’95 then moved to 1/8th on-road ’96-’99 (won the National in 2000). I brought myself a T4 for Christmas and enjoy racing it. No offence to all of our club members, but it is amazing how little knowledge is down there these days. The club has a very good turn out on Friday nights (50+ drivers) but their are lot member’s that don’t know of me at all at the track and ask me what am I doing to the car, why are you changing this and that, is that an new again why is it so clean and so on. After racing the Mugen MRX for 14years you pickup on the finer details in setting up a car and I now use this knowledge on my T4. I have spoken to member that haven’t changed or topped up the shocks oil in months and other drivers that don’t even check ride height. Some drivers are racing for fun, but having a car setup correctly is even more fun. I have been given on advice and help to a new father and son team. Simple things like don’t over tight your plastic nuts that hold the shocks on, what a slipper is for, correct tires choice and don’t use your race tires on the road and some driving tips. Matthew has gone from 38sec, down to 32 sec lap times and now racing other drivers.
How do you know when the o-rings need to be replaced?
Picked up my first lipos and made a blunder. The Lipos I got have the leads coming out the side. I was thinking I could remedy this by dremiling out the webbing in that section of the tray. I am thinking I am not the only one who has made this mistake. Do you think this will be ok or will it weaken the chassis to much? I will probably have to open up this area from front right of tray back about an inch because I have never used lipo in my Factory T4 and am not sure where I am going to have to place the batt. Thanks for any input.
now i know that losi and associated shock oil are different but i cant remember the difference. does anybody know?
The oil starts coming out of the shocks.
Losi is heavier by weight, if you had 30wt AE oil in your shocks you'd use 27.5 Losi to stay close to the same.
There's a good charg on twf8.ws in the tech section. Scroll down on the page, the first comparison chart is backwards, lower on the page there are charts where someone measured each brand's oil with a rheostat (I think this is the tool) to get their true rating on a common scale.
That's the page I was refering to. The Gene Hickerson chart near the top is backwards but otherwise a good guideline.
I am rather certain that the ae/losi oil chart is correct. Loai is thinner by weight. If you start with ae 30 and you want 27.5 you use losi 30.
We are still arguing which oil is thicker @Trcr...
I say Losi is thinner.....
I'm running inside on tower in the rear with outside on the arm. I can go in one more on the tower to the 4th hole but it feels too lazy
on the front I'm on the inside on arm and either middle or inside on tower
for links I'm running standard 1-b link in rear with no washers
in front I just switched to 1-b from 1-a and love it. I also have 2 washers under ballstud
30 degree blocks with 3 bump steer washers and spindles middle
Arms are level front and rear bones level
I put the 56 pistons in last night with 30 wt oil front and back. The 25 wt felt too soft
I also have rear hubs spaced back for more steering
any suggestions?
