RC10B4/T4 Forum
Trader Rating: 27 (100%+)
hey whats the easiest way to get more all around steering out of my t4 without losing the rear end? my truck is very planted right now and i know my set up is not far off, so im jus looking for a little more steering as i dont like "brake checking" my car into corners. other than that its good
Slow down even more when approaching the corners. Didn't think that you would like my answer. I got plenty more silly ones.
Can you give us some more info in regards to the setup of your car. Thanks.
Had a question about the Diff. gear Part #7664. I have built two T4 factory team kits one last year and one the year before. The gear diff 52T in the kits looks like it is Kevlar but the LHS have diff. gears the same part # but they look plastic. Did AE change the material at some point is their newer and older ones maybe. Any help would be appreciated Thanks
the stock ones are different colors, the aftermarket ones are black. no difference i think.
It looks like the Factory Team kit's came with Kevlar ones (above diff. gear for T4). The ones in the LHS look like they are plastic.???
it is molded out of a new material...same as the sc10 gear diff and idler gears. the old ones are black and the new is a cream tan kinda color. no performance difference.
I guess the Kevlar ones are the new ones then. They look like they are a lot tuffer then the black ones.
