RC10B4/T4 Forum
oh its def. been done and ive def. seen it and you all will def. see it in the future...
Centered motor mount assembly. Sounds like a B5 feature!
Do any of the other current 2wd Buggies have the motor mounted in the center?
I belive Kyosho has a kit coming for the RB5 to center up the brushless motors for better side to side weight distribution.
There is absolutely no B5 coming anytime soon. Especially not after the updates they just did to the B4/T4. There will only be continued updates to the current platform. The RB5 just came out with a new rear end that centers the brushless motors. I just recently saw a b4 with all kinds of funky shims in between the motor plate and trans and it did indeed have a longer topshaft. The owner claimed perfect left to right balance. However, i have seen this done before about a year back in this forum that maintained the original topshaft.
there arent any "updates" nothing is performance changing with these different parts. just beefier steering knuckles, sc10 motor guard, the orings in the newly made kits (which are soo much better) and the front and rear towers which arent out yet. nothing is performance changing and make one car better than another.
check and see what color the shock bodies are, if they are very silverish colored they are the very old ones, the up to date ones have a much darker anodizing on them.
for the B4
Stuff that has hit shelves
B4.1 has all the updates
Front Shock Tower(picture a few pages back)
Chassis (thicker bracing throughout)
Steering rack (sc10 plastic)
Spindle carriers (sc10 Plastic)
B4.1 body
Stuff that hasnt yet
Rear Tower (4th hole added, first hole removed, more space under the base of the tower for increased size lipos)
I dont know what besides the chassis has changed on the T4, Its a dead class anyways and will soon be replaced by SC haha
B4.1 body
To do the mod I bought some longer screws and used platic 0.60" shims that are used in the shocks. Shims are also required on the top shaft to space out the inner slipper plate. The motor pinion meshed fine with the spur and there didn't appear to be any issues with support or misalingment.
However the Kyosho upgrade that does a similar mod includes a big plastic spacer that would take up more load than simply adding washers.
I have since removed the washers until something more official comes out. It would be nice to do this as the Speedo is generally installed on the left side of the car and with the small receivers today the weight bias left to right is way off. I compared my ESC to the receiver and transponder and my car needed nearly a full ounce to be the same side to side. I just may move my speedo to the right side to offset the motor sticking out further on the left side.
Trader Rating: 27 (100%+)
dumb question guys, im new to the t4 that i recently picked second hand and wanted to know if there was anyway to identify if my car has the 30* or 25* caster c-hubs? thanks guys.
The 30 degree blocks, the hinge pin hole is off center, this is from having a 5 degree angle added to it.
To do anything more than 2mm you will need to use a different top shaft and press the gear onto it. The losi steel top shaft works well.
Don't forget that the rebuild kits have been updated. This is the biggest factor in helping the shocks, and keeping them from blowing out and, or leaking.
thanks for the quick reply
