RC10B4/T4 Forum
if your racing with anything under a 10.5 then tekin is really nothing special. LRP is waaay smoother. just get a sxx with a 9.5 and go drive the dang thing, dont worry about changing your power. gear it at a 78/27 set your slipper and go for it.
Your opinions... for a FT B4.
Tekin RS & Redline __.5
or
SXX Competition & X-12 __.5
or
_____________ & ________ ___.5
I've never owned either Tekin or LRP before, only run Castle products. Any advice?
Am currently leaning toward Tekin w/ a 10.5, but am very open to suggestions.
or
or
A 9.5 with 78/27? That's a little high for even a static timing speedo.
Having more flex will allow's the part more give on big hits .
Fewer break's as a result..
ok still having problems with car spinning out going around turns no one else at my track is running a 1/2 degree rear so i dont need that. just woundering if its something with my diff? to tight to loose? but it feels good..
Hard to say , have a experience racers at your track try your ride .
The diff usually never needs adjusting if you set it properly...
i dont know thing is i am a experiaced racer for 15 years lol just never had a problem like im having with my b4 seems every setup i try its the same like nothing changes tried 30degree hubs this weekend and didnt even feel a diference.. thinking of buying a losi
If you are spinning out due to a lack of traction ...
Adjust rear ride height. Lower rear ride height if on high grip surface, higher rear ride if on slippery surfaces...
also try
*softer rear spring
*move rear hub forward
*check your slipper , to tight will not help your problem
*adjust ESC coast brake to smoother setting & also try a lower punch or power profile...
also try
*softer rear spring
im gonna print out a setup sheet and fill it out and upload it maybe someone can find where im going wrong.
If you are running a setup that others are having success with and are confident that the condition of the car is good (diff not shot, shocks full, no binding in the suspension) then its probably the tires. Foams shot? rubber dried up? Sometimes the difference between new and old of the same tire can be large.
This is a disappointment because ae really needs to come up with some new instead of wasting their time with the b4.1 and t4.1. They are stupid. Secondly, they were lazy by changing just the molds of the shocks to new molds. They have been using the same molds from ten years ago I believe. Not dissing them but it is like the auto companies, they cut corners at every opportunity instead of doing the right thing.
Amen.
AE is very good with their cars, you really shouldn't need radical changes. My suggestion is to either A- talk to the local hot-shoe and have them either share their setup OR drive the car. Typically, if THEY struggle with the car, its in the setup.
Thats the worst idea ever, IMO. You realize LOSI isn't the same "race oriented company" it once was? IF you switch, I would look at Kyosho. They seem to have the racing figured out (Tebo just took the mid west champs IIRC) and from all accounts, they are making some pretty nice cars. I hear the shocks are butter!
Best of luck man. Don't get overly worked up, just start with a clean slate and make small changes. Shocks and oil, Springs, even check the Anti-Squat. Re-read the manual esp. on how certain changes will affect the car. (I haven't raced in quite a while and I have to re-learn this stuff,) and Im twice as old as you are and racing that many years!
MOmo
also try
*softer rear spring
also try
*softer rear spring
move the lower shock in
lighter oil
shorter rear link
more camber
Try reducing drag brake on the ESC. Turn down the Brake EPA on the radio. Those two make a huge difference in how a vehicle reacts. Also check all four hub bearings in the rear make sure they're in good condition. Check that the CV shafts/axles are lightly coated with grease.....not dry or rusty.
either is associated since they are owned by thunder tiger. And have you seen their latest creations, the t4.1. Wow, that was hard to design. And the sc18, not a market scam at all. =)
